DTT is coming along, the question I have, is when applying the BLM tables, and something is outside of it's correction parameters, do I need to fix it, or does resetting do what I need? \\; The other thing is, this morning I got a little pinging when rolling on the throttle at lower RPM's which I have not seen before, I don't know if it's just too rich, or if I need to pull a little timing out of it. \\; Do I just go the edit user function page and retard the timing a little, or is there a different way. \\; I was going to wait a bit before going down that road.
Thanks for the compliment on the wheels, I'm pretty happy with them. \\; Was at a little show and shine last night, and it definitly sets it apart from all the other glides.
DTT is coming along, the question I have, is when applying the BLM tables, and something is outside of it's correction parameters, do I need to fix it, or does resetting do what I need? \\;\\\\\\; The other thing is, this morning I got a little pinging when rolling on the throttle at lower RPM's which I have not seen before, I don't know if it's just too rich, or if I need to pull a little timing out of it. \\;\\\\\\; Do I just go the edit user function page and retard the timing a little, or is there a different way. \\;\\\\\\; I was going to wait a bit before going down that road.
Thanks for the compliment on the wheels, I'm pretty happy with them. \\;\\\\\\; Was at a little show and shine last night, and it definitly sets it apart from all the other glides.
PM SpikeCT, Dalton, \\;or PhilM in regards to your DTT questions. \\; These guys are adept at setting one up and optimizing the parameters.
