Is the SERT adjustable?
Old May 10, 2008 | 06:39 PM
grimminator's Avatar
grimminator
Default Is the SERT adjustable?
I have a 06 street glide with SE 103" SE heads ,true duals V&H, stage one air cleaner. The dealer installed the SERT but I am getting some decel. popping and even some accel popping. Is the SERT adjustable,or would you recommend going with the PC III or another programmer? If I went with another programmer would I have to UN install the SERT,or can I program over the existing? My concern is I dont want the bike to run lean and over heat. I have not installed the oil temp. gauge yet,so I am not sure how hot its running. I have a temp. gun is there a certain temp. at the front cyl. that is acceptable? I heard the front cyl. runs hotter than the rear. Thanks in advance!!
Old May 10, 2008 | 06:48 PM
Jinks's Avatar
Jinks
Default RE: Is the SERT adjustable?
Wrong! The rear cylinder runs hotter. Yes, the SERT is adjustable. No, you don't want to try to mount a PC-III over the SERT. Install an oil temp. gauge, you want to run between 190 (adjusted for gauge discrepency) & 230 deg. 250 to 280 on a hot day at idle is tollerable for a short time.
masterblaster's Avatar
masterblaster
Your dealer should be able to tune the popping out using the SERT and dyno, might be the cheapest way to go, if the dealer cant do it a good indy tuner can.
Old May 10, 2008 | 06:51 PM
Mandog's Avatar
Mandog
ORIGINAL: grimminator
Thats the whole point of the sert, To adjust and fine tune your bike.
Old May 10, 2008 | 07:17 PM
winston chopper's Avatar
winston chopper
tHAT SHOULD HAVE BEEN WORKED OUT WHEN THEY INSTALLED IT. SOUNDS LIKE THEY NEED TO RETUNE. tHAT SHOULD BE AT NO COST. iT IS NOT THAT DIFFICULT AND THERE IS NO REASON WHY ANY DEALER CANT DO IT TO A SATISFACTORY LEVEL. tHATS WHAY YOU ARE PAYING FOR DYNO TIME FOR. jUST BRING IT BACK AND TELL THEM WHAT YOU POSTED HERE.
Old May 10, 2008 | 07:34 PM
djcustom1's Avatar
djcustom1
Yes, iwould take itback to the dealer and make them tune it wright or ask for your money back and go some where else.
Old May 10, 2008 | 08:01 PM
Ultra007's Avatar
Ultra007
Lean, lean, lean.
You don't mention cams. 103" w/ SE heads (not sure which ones), true duals, air cleaner but hopefully not stock cams. Otherwise even leaner.
Too much head (yes, there is such a thing) on top of not enough motor will cause the same symptoms.
U
SMacDunk
Jan 23, 2008 05:18 PM
cjuetten
Jul 25, 2007 07:49 PM
murf1
Apr 29, 2007 10:53 PM
Stumpman
May 24, 2006 08:02 PM
Angry_Monkey
Mar 16, 2006 10:39 AM
