Crankcase vent VALVE question
Old May 10, 2008 | 11:51 PM
CREEPSHOW's Avatar
CREEPSHOW
Default Crankcase vent VALVE question
Have a local HD guy tell me thatI should have a one way valve on my crankcase vent. Says dyno results have showed hp gains from adding this. Anyone else heard of this?? Mine is just open.
Old May 11, 2008 | 02:21 AM
Bill03E's Avatar
Bill03E
Default RE: Crankcase vent VALVE question
I would think it wouldn't make ,any big difference, was he trying to sell you a one way valve?
Old May 11, 2008 | 06:01 AM
CREEPSHOW's Avatar
CREEPSHOW
ORIGINAL: Bill03E
No.
Old May 13, 2008 | 06:29 AM
winston chopper's Avatar
winston chopper
I was talkin to my wrench , he said he thought thta sounded legit. Its like a pvc on a car engine I guess.
Old May 13, 2008 | 07:54 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Sounds like another guarenteed7 to 10 horsepower to me.......
Old May 13, 2008 | 08:00 AM
PhilM's Avatar
PhilM
The Doherty Power Vents that come with their intake setup are one-way valves.
Think about the displace air that is pushed away from the back side of either piston as it descends... It's like a sudden positive pressure pulse inside the crankcase. Then think about the "negative pressure" scenario that occurs when the piston(s) ascend. The net result would look something like a sine wave if it were graphed.
What the one-way does is basically "chop off" the negative part of that pulse, thus reducing the overall amount of air that is being forced to move about inside the crankcase.
Does that translate to tangible or measurable power??? F... if I know. It does seem to make sense, at least in my pea brain...
And, yes.... I do have those vents on my scoot...
Old May 13, 2008 | 08:21 AM
Zimbob's Avatar
Zimbob
Niterider has some interesting reading on this issue. I think it was niterider, anyway, the scoot was dynoed with the vents open, with a one way and sealed off, according to the graphs, no difference on any of the runs. I took it for what it was worth.
Old May 13, 2008 | 08:31 AM
honestbob's Avatar
honestbob
put a check valve on '98 dyna, no differance. left it on anyway
Old May 13, 2008 | 09:19 AM
twincam47's Avatar
twincam47
you have crankcase breather check valves that are one-way in each head and port to the air cleaner banjo bolts, what are you guys talking about?
Old May 13, 2008 | 09:22 AM
liltrk's Avatar
liltrk
I think he may mean the one that exits the back of the engine at the bottom.
cajun1957a
Shovelhead
Oct 18, 2014 09:41 PM
SafetyMan
Nov 13, 2013 04:04 PM
harleycharlie1992
Aug 30, 2013 10:55 AM
gsxrboy96
EVO
32
Jan 17, 2010 10:05 PM
mikeurig
Nov 5, 2006 10:55 AM
