Engine Cases
Old May 13, 2008 | 10:45 PM
scooter34's Avatar
scooter34
Default Engine Cases
I have 600 miles on my 08 FLHTC, anyway is it normal for the front of the engine cases(where it splits) to have what looks to be "wet" with oil? Any help would be appreciated
Old May 14, 2008 | 06:43 AM
Peppa1's Avatar
Peppa1
Default RE: Engine Cases
NO it is not normal. This has been a real problem on some of the 08 models. As you stated the cases are actually weeping. I have a friend that bought 08 Ultra, Anniversary bike and he had the same problem. They had to tear his bike down and replace the cases. You need to take it back to dealer and have them do the same for you. Tell them you know for a fact that this is a problem on some bikes and you want it fixed right. Good luck !!
Old May 14, 2008 | 06:51 AM
rocknrod's Avatar
rocknrod
I would bet that the EPA would say that new vehicles are not to have oil weeping from their cases.
In fact call the EPA- Technical Issues personGene Tierney at (202)343-9267.
Someone there would tell you the facts.
And Harley is no different than any other vehicle manufacturer. They have to follow the rules.
Old May 14, 2008 | 08:43 AM
twincam47's Avatar
twincam47
Before you through H-D under the bus....with only 600 miles on the new bike....the least bit of oil on the engine will spread when it gets hot and make it look like a gallon is on the engine.
I would use something like simple green to clean the engine and then watch the area again. Also remember that your front wheel transfers road stuff to that area....I wouldnt jump on a pourous case band wagon just yet.
Old May 14, 2008 | 08:55 AM
uweldit's Avatar
uweldit
I had the same problem on a 07 Dyna. It's not normal and yuou should take it to the dealer for repair. Take a picture of the leaky area first.
Mine leaked in the same location after less than 100 mi after purchase. Dealer fixed it and no more leaks.
Old May 14, 2008 | 08:57 AM
twincam47's Avatar
twincam47
ORIGINAL: uweldit
how did the dealer fix it?
Old May 14, 2008 | 12:58 PM
hdmunro's Avatar
hdmunro
well make sure to get it fixed while under guarantee, because i had the same thing on a 2000 fatboy that
didnt surface right away, and they wouldnt fix it till i really REALLY bitched about it, even though its an
obvious defect, after 4 years (i had extended guarantee) they dont consider it thier problem anymore.
just a heads up....it only seemed to weep near the oil filter, and i always assumed it was from the maintenence, never had a lot of oil, i assume it would burn off....they only noticed it when i had the 95" upgrade, and they noticed the pocks in the lower case....
Bill
Steve Cole
Milwaukee Eight (M8)
121
Sep 18, 2018 12:46 PM
MattDunne
Aug 12, 2018 11:01 PM
Andrew49238
Classic
May 22, 2018 06:44 AM
RedLewy
Mar 20, 2018 02:31 PM
giacomo56
Feb 4, 2018 06:29 PM
