Right Turns
Old May 15, 2008 | 11:05 AM
mtairy biker's Avatar
mtairy biker
Default RE: Right Turns
try takeing the experinced rider class at you DMV or local collage it is throw MSF. It is a good referser corse.
Old May 15, 2008 | 11:07 AM
Gart's Avatar
Gart
It is all a mental thing. You can overcome by practicing. Seating position, clutch, brake, throttle usage, etc. You'll figure it out if you work at it.
Old May 15, 2008 | 11:08 AM
frontiercat's Avatar
frontiercat
Has more to do with control of the throttle (grip not as tight on the bar) and left brain thinking. I had issues with this years ago. Just got some small soccer orange cones, went to a local parking lot after dark and tried every move that I could imagine. A lot of it has to do with confidence and the bike's center of gravity.
I rode a lot on dirt bikes through trees and trails (differing speeds, inclines, and maneuvering) as a much younger buck. Keeping a two stroke KX250 upright on the trails taught me alot, but getting on a 720 lb bike with a much different center of gravity required a whole new set of "mind sets".
As always, look where you want to go and feel the bike. Honestly, since I put on my rider's back rest, I feel more in control of the bike than ever before. Why, I don't know.
Old May 15, 2008 | 11:16 AM
dirtdobber's Avatar
dirtdobber
Glad you posted this. My wife is haveing problems with right turns. She hasn't rode in 20 years; so she says. She has took the MSF course. After showing her this she feels better. She was almost ready to give up. Personaly speaking I can not add any help without seeing you ride.
Thanks
Old May 15, 2008 | 11:41 AM
BlackBagger's Avatar
BlackBagger
Taught this a while back.
In the US where we drive on the right side of the road, Left turns tend to give the driver more room to manage the turn. Right turns are usually quicker and sharper.
(in a vehicle you also add the fact you sit left and see left easier)
Go to a parking lot and set up a "T" intersection, ride straight at it and make alternating turns from 15' and 30'. you will find that the longer distance is easier left or right, but, when you drop to 15' both turns will be more difficult. Remember to look through the turn at a spot where your bike will be straight again and it will help you through.
Several years of Pursuit Driving and Dignitary Protection finally pays off.
Mg
Old May 15, 2008 | 12:23 PM
Beemervet's Avatar
Beemervet
No no no............you are all wrong.
The real secret is...................
Three left turns equal one right!!!
Old May 15, 2008 | 12:29 PM
TonyVT's Avatar
TonyVT
I found that turning my head to the right and looking where I wanted to go while using the friction zone until I completed the turn worked wonders.
Old May 15, 2008 | 12:37 PM
jakedog's Avatar
jakedog
ORIGINAL: TonyVT
+1 get "Ride Like A Pro" DVD.....
JD
Old May 15, 2008 | 12:49 PM
beary's Avatar
beary
I think the difference is in the throttle. I have the opposite problem, I have a harder time turning tight left turns. After a lot of aggravation and observation, I figure out it is the angle of my left hand while holding the clutch. My clutch is pretty tough, which makes it harderto feather through the friction zone when my left hand is closer to my body in a left turn. I’m looking for a new cable to soften it a bit, but I’ll bet your new handle bars put your hand in a different angle than you’re use to from your old ones.
Just a different perspective. .
Beary
Old May 15, 2008 | 12:55 PM
fxdwg_rugby's Avatar
fxdwg_rugby
Practice in a parking lot but my bet is you'll get used to it in less then 1000 miles...I had 80,K miles on my WG when I bought an Ultra. Just some time and practice...
