Looked at 08 SG's
Old May 18, 2008 | 02:22 PM
rocknrod's Avatar
rocknrod
Default RE: Looked at 08 SG's
Okay I cut and pasted from the 08 touring family changes. This is from HD:
NEW
Electronic Throttle Control
• New throttle grip sensor and
induction module
• Sends rider input to ECM
electronically
• Eliminates throttle cables
• ETC throttle grip sensor wiring
inside handlebar
• Throttle plate position
controlled by the ECM
• Will not retrofit
[b]
NEW
ECM / Location
[font=arial]
• Now under seat
• Positive retention on harness
connector
• New ECM caddy
• ECM controls cruise control
and throttle plate
• Cruise control module
eliminated
• Battery terminals top mounted
[b]
NEW
Frame Changes
[font=arial][size=5]
• New purge solenoid mount; same
location now riveted to frame
• Redesigned front motor mount to
limit travel
• Redesigned battery tray and horn
bracket integrated with the frame
• Horn bracket not a lifting point for
engine
• Front stabilizer link
relocation
• Redesigned front cylinder head
for stabilizer bracket
[b]
Brembo
® Brakes
• New 300mm semi-floating brake rotors
brake pad material and calipers
• Two piece design rear caliper/mount
• Brake lines, clutch levers, and foot
levers are all new
• Bleed screw incorporated
into banjo bolt on front calipers
• Calipers are not rebuildable
• Use Dot 4 brake fluid
[b]
ABS Brake System
• New ABS pump and lines
• Non-linked system
• Digital Technician ll needed to
bleed ABS Brakes
• OE factory option for all FL
touring models
• Footboard and brake pedals
on FL Softail
® [font=arial][size=5]and Touring
models will be commonized
for 2008 models
• Behind right side cover
[b][font=arial][size=5]
• 2008 wheel hubs are machined
[left][size=3]to accomm
Old May 18, 2008 | 02:44 PM
leohd's Avatar
leohd
damn I like my dinosoar, but a6 gallon tank would be nice
Old May 18, 2008 | 03:03 PM
JimTJr's Avatar
JimTJr
Thanks Rocknrod, Guess if I get a good enough buy on the 07, it would be fine. There is a Preseason sale, less than 19k for a new SG, but the 07s seem to be going for the 16 range on ebay, some a tad higher.
Old May 18, 2008 | 04:21 PM
Trock's Avatar
Trock
Damn for $400 you would think they could spell right on there web page
Old May 18, 2008 | 08:44 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: JimTJr
Oh yes, I know that dealer is pitiful. (Not going to mention the name, in St. Charles, MO.) LOL.....
Stay away from Bob Schultz and take a nice ride over to Ted's in Alton. They'll tell you the truth. Of course, they sell so many bikes that they don't have any left over '07s.
Jackpoticorn
Aug 25, 2014 02:46 PM
Texas Fat Boy
Nov 23, 2011 03:02 PM
vetto
Shovelhead
Nov 5, 2008 07:31 PM
ridemhard
Sep 23, 2007 09:13 PM
Hawk45
Jan 1, 2007 12:45 PM
