PCIII installation question
Old May 19, 2008 | 11:40 AM
harleyduck's Avatar
harleyduck
Default PCIII installation question
Anybody that has installed this in a 08 ultra classic, i wold appreciate a little help. The instructions say its a little tight, but that is definitely an understatement.. My question is, do you need to use a dremel tool to modify the ecm tray and the cover coming down from the tank that protects the wires from the front of the bike. This is the only way i can see to install like the instructions say. I just need someone who has done it to tell me what problems they ran into. thanks for the help
Old May 19, 2008 | 12:23 PM
JoeSwiatek's Avatar
JoeSwiatek
Default RE: PCIII installation question
Trim off the forward edge of the ECM tray and everything fits perfectly. Use patience when installing this stuff.
Old May 19, 2008 | 01:48 PM
harleyduck's Avatar
harleyduck
Thanks Joe, I did indeed have to trim off the edge that you talked about. It was a tight fit, but finally got it done. I had to trim off the v-shaped plastic covering the wires at the bottom of the tank to get part of the wires to tuck under and out of the way. After that, I slipped into place and all done! Now if I could just get my laptop to work and set the throttle position for open and closed. Again, thanks for the post...and now for the test ride.
Cjohnston5509
Jul 31, 2016 08:13 PM
ArcaneEdge
Sep 18, 2014 07:19 PM
mikebaby
May 3, 2012 08:03 PM
Hog Heaven
May 1, 2008 06:05 PM
LOTHAR
Oct 19, 2006 06:19 PM
