Pressure gauge for tires
Old May 19, 2008 | 03:46 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Default RE: Pressure gauge for tires
ORIGINAL: fotoflojoe
...Can anybody recommend a good tire pressure gauge?...
You might want to try the EZAir by Accu-Gage...uses flexible hose with clip attachment.
Old May 19, 2008 | 04:15 PM
PHREDD71's Avatar
PHREDD71
Found a pencil style gauge, but it is only half as long as the normal kind. Allows me to get the angle right so I can get a decent reading on the back tire. They had them up at the register for like $3. Works fine. Has a little magnet so it sticks to the metal pin in the saddlebag so I do not lose it.
Old May 19, 2008 | 04:26 PM
IBHarley's Avatar
IBHarley
get a decent digital guage at walmart or sears about 10.00 get the pressure right to even half pounds
Old May 19, 2008 | 06:52 PM
jimsuver's Avatar
jimsuver
I also like the H-D one with the hose. Its easy to use on the rear tire and the depth gauge is cool.
Old May 19, 2008 | 06:56 PM
oldhippie's Avatar
oldhippie
ORIGINAL: hoosierhog88
I got one of the HD models for a Christmas present a couple of years ago. It has a depth gauage too. $29.95 retail. Yes, it's too expensive, but I didn't buy it.
+1 on this HD guage.. works nice as far as fit is concerned and keeps the reading untilyou zero it,and feels solid and I "think" it is accurate.
Old May 19, 2008 | 07:00 PM
capt_caveman's Avatar
capt_caveman
ORIGINAL: Amodump001
Haven’t used it myself but my brother uses a cap that transmits the air and temp to an gage mounted on his faring. Thinking of picking up a set for mine.
That sounds interesting. Do you have a link?
Old May 19, 2008 | 07:23 PM
rjhammetter's Avatar
rjhammetter
6th Gear
Not to hijack - but this loosely counts as a tire pressure gauge-
http://www.smartire.com/motorcycles
I wanted to add this to my previous cycle but didn't have the money. I've heard mixed reviews. Can anyone who uses/used it comment on quality/usefulness/accuracy?
Old May 19, 2008 | 09:13 PM
Uncle Scrooge's Avatar
Uncle Scrooge
The Harley stick gauge with a 90 degree chuck works good. About $12-13.
Old May 19, 2008 | 10:15 PM
1flhtk4me's Avatar
1flhtk4me
I bought a digital Craftsman.
Old May 20, 2008 | 07:12 AM
Theakerr's Avatar
Theakerr
Made my own along the same lines as the HD and progressive no loss air shock gauges. I was so fed up with losing air out of the rear tire every time I tried to check the tire pressure on my EG because i could not get the gauge on at the correct angle. Used a screw on right angle valve extender but am currently building a second one using a dual rear wheel screw on flexible tire connector, bought a round analogue gauge with a pressure let down button (I suspect i am under pressure I just over inflate slightly and let down to target pressure) removed applicable internals, added an extra O ring to the screw on end and JB Welded the assembly together
