1996 ultra miss
Old May 20, 2008 | 01:55 PM
steve marshall's Avatar
steve marshall
6th Gear
Default 1996 ultra miss
Im frustrated, my 1996 ultra runs great for about an hour. After that she starts to spit and sputter and spit black smoke and die. if i let her set a little she will eventually start but i have to hold the throttle open for a few minutes to let it blow itself out and then shes fine for another hour or so. i dont work on bikes, any ideas???????
Old May 20, 2008 | 02:52 PM
miacycles's Avatar
miacycles
Default RE: 1996 ultra miss
When it stops and wont start se if you have spark. If you do rebuild/replace the carb, black smoke usuall means rich!!
Old May 20, 2008 | 03:53 PM
DeJavu's Avatar
DeJavu
Sounds like your float valve is sticking open, flooding the carb. I think a carb rebuild will take care of things. Do you see any signs of a fuel leak at the overflow outlet, drain tube or air cleaner?
Old May 20, 2008 | 07:39 PM
steve marshall
6th Gear
the bike is fuel inj.
Old Jul 23, 2008 | 07:17 PM
steve marshall
6th Gear
I finally broke down and put her in the shop. Dealer has ordered a engine temp. sensor.&nbsp\\;&nbsp\\; i will keep everyone posted.
Old Jul 26, 2008 | 10:48 PM
steve marshall
6th Gear
YEAH!!!!!! i have run out 2 tanks of gas in the last 2 days.&nbsp\\; not problem so far.&nbsp\\; not bad for 298 dollars
Old Jul 27, 2008 | 12:38 AM
phat96's Avatar
phat96
As long as she is running and your happy, then that's all that matters. Mine 96 RK fuel-Inj also.
djgriff
Nov 30, 2017 04:27 PM
un-caged
Jul 25, 2017 02:03 PM
leadsled70
Aug 7, 2014 08:26 AM
All Aces
EVO
16
Jul 12, 2014 06:27 AM
PyroPornStar
Exhaust System Topics
Apr 21, 2013 06:57 AM
