Handling 08 SG
Old May 20, 2008 | 08:28 PM
Kid Rat's Avatar
Kid Rat
4th Gear
Default Handling 08 SG
OK, I have heard & read they are the smoothest handling mc out there @ low speeds especially. Then why is it anytime I get anywhere near 45 degrees it want's to dump on me. (lay down) I have no problems other than between 0-5 mph.I have been riding a FatBoy for 10 years and have never even come close to laying it down. What gives? Noted, it is a little more noticable when riding 2 up, which is a problem I have never felt on my Fatboy. (which is lowered) I have been looking into a lower shock, even though it's liable to void the warranty. the same as an air assist program. I have considered a lower profile seat, or at least not as wide. Tommorow, I am gonna play with the adjustable air ride system, see if that makes a difference. Any comments at all would be appreciated.
Old May 20, 2008 | 08:54 PM
Kid Rat's Avatar
Kid Rat
4th Gear
Default RE: Handling 08 SG
bump
Old May 20, 2008 | 09:09 PM
Kid Rat's Avatar
Kid Rat
4th Gear
C'mon people work with me, Will raising the bars make a difference?
Old May 20, 2008 | 09:19 PM
DrSmaggs's Avatar
DrSmaggs
I wouldn't know if raising the bars would help. That's all about personal preference.
My Dyna has mid controls with forward pegs. I like having my weight on the mid control pegs when maneuvering like that. I used to have one hell of a time making any speed of right hand turn. Just anytime I had to go right sucked!
I look through all my turns and I've taken extra time to get to know my stopping distance and how to turn at very slow speeds.
I do get that "gonna dump it" feeling at slow speeds, but I never do. I think it's just awkward going that slow. Anything less than 20 MPH is like muscling the bike rather than riding it.
Old May 20, 2008 | 09:41 PM
bgkv77's Avatar
bgkv77
You have more riding expeience than I, but for what it's woth..
I ride an '07 road king. I was taught to ride with the ol' friction zone, drag the rear brake technique. The way first gear is geared, for me, if i let the power away from the rear wheel the bike lugs and slows and wants to dump. 0-5mph sems pretty slow i would say my slow manuver speed is closer to +-10mph I would think. You have been riding 10+ years so I am sure you arleadyknow whatI am talking about. Just thought i would try to help things get started. Help him out here guys!!
Time2ride's Avatar
Time2ride
ORIGINAL: Kid Rat
You've heard and read that the ROAD GLIDE is the smoothest... not the Street Glide. You have the weight of the fairing on the handlebars with the SG, not so with your Fat Boy or with a RG. Low speed manuevering with a handlebar mounted fairing takes some getting used to, and even after you're used to it the weight of the fairing is always there and always a factor.
Old May 20, 2008 | 09:47 PM
kjmorgan's Avatar
kjmorgan
ORIGINAL: Kid Rat
I could be wrong but there's no reason to even be trying to lean a motorcycle 45 degrees at 5 MPH. You increase the lean angle to keep the turn radius the same as the speed increases. At 5 MPH, you turn the handlebars, shift your butt a bit and TURN!
Old May 20, 2008 | 10:10 PM
Kid Rat's Avatar
Kid Rat
4th Gear
I think you said it best morgan, ride it like you stoled it. I guess I have been intimidated by the extra weight & have let that factor into my thinking. I will still play with the air shocks tomorrow and see if that helps me feel a little more stable at low speeds rideing 2 up. Alone I have no problems.
Old May 20, 2008 | 10:13 PM
flyingace's Avatar
flyingace
ORIGINAL: Time2ride
+1
You've got 30 pounds or so up on your handlebars. That WILL affect how the bike feels in low speed turns. You get used to it, you learn to compensate for it, but you always need to be aware of it, and paying attention to it. The VERY few people I have ever let ride my bike, get a lecture about it before they get on the bike, because most people have never ridden a bike with a batwing full of stereo, gauges, etc, and the weight they ad to the steering.
Tell ya what, you think the harley is bad, test ride a Yamaha Royal Star Venture sometime... HOLY CRAP!
Old May 20, 2008 | 11:10 PM
Harleypingman's Avatar
Harleypingman
KR--if you expect an answer to a riding topic as your OP was written within 26 minutes (time lapse from OP to your bump) then bump it again 15 minutes later, you will wear out your patience.
If you want some good information on how to ride your bike at low speeds, buy the Ride Like A Pro V DVD and practice what it shows.
