Mileage test
Old May 20, 2008 | 11:55 PM
MikeB's Avatar
MikeB
Default Mileage test
Last weekend I set out to see what kind of mileage and tank range I could get on my 08 Ultra. Riding east of Burney CA towards Alturas, Cedarville and Gerlach NV I was able to get 257 miles out of the 6 gallon tank with .8 of a gallon left. I also got 49.4 miles to the gallon. I was riding fairly soft and didn't go over 70 mph. I am amazed at these numbers from such a big bike.
Old May 21, 2008 | 12:00 AM
Bertk's Avatar
Bertk
Default RE: Mileage test
That's excellent mileage. Is the engine completely stock?
Old May 21, 2008 | 10:51 PM
MikeB's Avatar
MikeB
Yes, no cams or anything like that. Just the stage I upgrade with the SERT.
Old May 22, 2008 | 08:04 AM
wagsrk08's Avatar
wagsrk08
MikeB: That is excellent mileage. How many miles do you curently have on your 08 Ultra? I have under 3500 on my 08 FLHR and best I've done is 41 mpg with same mods. Worst was 30 mpg last weekend at 65 mph with 20-30 mph winds evengusting higher. I felt like a kite! Good for you on you mpg.
Old May 22, 2008 | 08:31 AM
rjgraham's Avatar
rjgraham
nice, Im happy with anything in the 40's
Old May 22, 2008 | 12:31 PM
iclick's Avatar
iclick
That's about the upper end of what the TC96 can get, IMO. My '07 SG can manage 50mpg, but not much more, on easy backroads riding--lower in city. No amount of further tweaking will realize better mileage on this bike, so I think I'm at my limit. Last week I got 50mpg going to Gulfport, MS on the backroads, 45mpg on the return trip via I-10 with a moderate headwind and ~70mph cruising speed. I was very happy with that.
A friend in Lafayette, LA says he's gotten 50mpg on his '08 Ultra, which is stock, so it is certainly doable. If you are running closed-loop without the 14.2:1 change via SERT, you are running 14.7:1 in the cruise range with or without the Stage 1 download. This is most of the reason for good mileage on stock bikes, but usually this means more heat, as the A/F in closed-loop mode is very lean.
I have the PCIII with a map obtained from Fuel Moto that has been tweaked for mileage, Rush with FM custom baffles, and K&N AC. There are quite a few threads already here that discuss increasing mileage with the PCIII, and the same techniques would work with SERT.
Old May 22, 2008 | 02:54 PM
OregonRoadKing's Avatar
OregonRoadKing
I've been getting 30-35 mpg. Now at 4K I've gotten 40 mpg on the last two tanks with a mix of in-town, freeway, and twisty coast range roads with no restraint on the throttle.
Old May 22, 2008 | 07:25 PM
Bldr1000's Avatar
Bldr1000
On my 07 unltra with download and Vance and Hines , I get 36 miles per gallon...Bldr
Old May 22, 2008 | 08:36 PM
fireglider's Avatar
fireglider
On my 07 Ultra with almost 18,000 miles I'm getting 35-38 in town and 43-50 highway.
Old May 22, 2008 | 08:45 PM
Tinkermc's Avatar
Tinkermc
I get mid to upper 40s
