i'd buy the kromeworks if i didn't have to switch out the cables. are we 100% sure no switching of cables needed for an 07 sg? i might even take 98%.
It can be done with a re-route of the clutch cable. When I had them on my 04 I originally went without changing the throttle cables, but I felt it was a little too sticky for my liking so I changed out the cables. I changed out the clutch just because I thought it looked better routed the way it was supposed to be. You do not need to change any brake lines. As for the 08's you obviously just need a clutch cable which is the same part number except for -08 suffix. As stated they now make the bars with the notches....I adapted a set awhile back.
