255 cam & tmat
Old May 23, 2008 | 02:39 PM
RoadK45's Avatar
RoadK45
Default 255 cam & tmat
Sombody out there in HDforum land has to have a 103 with 255 cams and a tmat. If so just wondering what base map you started with because zippers tech line so far hase not helped much.
Old May 23, 2008 | 06:58 PM
RoadK45's Avatar
RoadK45
Default RE: 255 cam & tmat
nevermind i decided to pull the 255 and put in red shift 577s.
Old May 23, 2008 | 09:45 PM
wuznme's Avatar
wuznme
Is the map you tried not working anymore?TMAX should have told you to use 398 or 414...Is your bike detonating? Did they tell there test mule did as well? The 320 map should have been close; only difference was the head selection.
Think I am going to go down a different path instead of tearing into the engine. Just not sure if I want to use DTT or a SERT.
Old May 23, 2008 | 10:06 PM
RoadK45's Avatar
RoadK45
map 320 works ok i thought about using the 255 timeing from a different map. Yes zippers told me the same thing that 255 with stock heads creates ping, either change heads or cams to fix.
Pur3vil
Jul 20, 2018 01:16 AM
Buiceman
May 8, 2015 11:14 PM
msr082881
Feb 20, 2015 04:28 PM
pedallingfool
Apr 23, 2011 12:11 PM
vtwinbmx
Mar 25, 2009 01:55 PM
