Starting my 103 Build need calibration File
Old Mar 25, 2009 | 01:26 PM
vtwinbmx's Avatar
vtwinbmx
Default Starting my 103 Build need calibration File
Parts list. SE Flat top Pistons, SE251, Cometic .030 Head Gasket. Looking over the TTS list there is a map for a 255 Cam. Is this close enough or does somebody have a calibration using the 251 cam? Any input would be great.
Old Mar 25, 2009 | 01:48 PM
Dr. Combustion's Avatar
Dr. Combustion
I have a similar build but with 204 cams. I tried the file for the 255's, but I had an off-idle stumble. Doc advised to use the TQ205 as a base map. I needed four (4) V-tune runs for the map to be dialed it, but it worked very well. You may want to PMl Doc or Steve Cole for their advice.
Old Mar 25, 2009 | 01:55 PM
vtwinbmx's Avatar
vtwinbmx
Thanks For your input. Will PM Doc
Roadflyer
The Dyno Room
Jun 12, 2017 08:26 AM
shootist57
The Dyno Room
Mar 14, 2017 09:55 AM
Big Money
Jun 26, 2015 06:03 PM
pedallingfool
Apr 23, 2011 12:11 PM
RoadK45
May 23, 2008 10:06 PM
