Squirming on the Road.
Old May 24, 2008 | 07:07 AM
0204665J's Avatar
0204665J
Default Squirming on the Road.
I notice lately on my Street Glide I get a feeling of squirming on the road. Kind of link a snake moving on the ground for very short instances. Usually occurs at 55 or more and happens most of the time over rougher road surfaces. Tires are me880 which have been great and have about 8000 miles on them.
Now the only thing I am aware of is I do need to replace my rear tire and I plan to do so next week. My motor mounts are fine.
Any ideas out there. Feels like the start of a wobble, but can be sure. I do have a true-track as well.
Old May 24, 2008 | 07:21 AM
Thundercloud's Avatar
Thundercloud
Default RE: Squirming on the Road.
Maybe a dumb question, but have you checked the air pressure in your tires lately??
Old May 24, 2008 | 07:35 AM
blueflht's Avatar
blueflht
check axle torque. check wheel bearings. i also use avon venom tires 150 in the rear 130 up front. very good rubber!
Old May 24, 2008 | 07:56 AM
Bug's Avatar
Bug
You can run your hand over the surface of the tire and check for uneven wear or cupping on the rear tire. That many miles on a Metz and it is probably spent.
Sometimes even when you still have enough tread the tire can wear funny depending on riding style and air pressure and other factors.
Also, as the as Thundercloud said, too low of tire pressure can cause it to squirm like that. I think metz recommends higher pressures than Dunlop.
Old May 24, 2008 | 07:59 AM
dog155's Avatar
dog155
If is not anything in the suspension it has to be tire pressure,Good Luck
Old May 24, 2008 | 09:46 AM
0204665J's Avatar
0204665J
I run 48 PSI is the rear but will check it again....Just checked last week....
Got 440 progressive HD in the rear and gold value race emulators in the front.
Old May 24, 2008 | 10:15 AM
gambler's Avatar
gambler
This may sound simple, but make sure your seat is securely tightened. I have experienced that feeling when the back of my seat was loose.
Old May 24, 2008 | 10:47 AM
Beemervet's Avatar
Beemervet
New tire
Old May 24, 2008 | 11:48 PM
1ADAM12's Avatar
1ADAM12
Since i put metzlers on it stopped i wont run dunlops again good luck
Old May 27, 2008 | 09:51 AM
0204665J's Avatar
0204665J
Yep, Check rear tire presssure and it was 38. 10 lower than normal. Last time the son checks it for me...that alone with a worm tire seems to be the problem. New tire next week when I get it in.
