Painting a fender
Old Feb 27, 2006 | 12:15 AM
Candy Red Road Glide's Avatar
Default Painting a fender
Anyone have a good guess at what the cost to paint a rear road glide fender vivid black? thanks in advance
Old Feb 27, 2006 | 11:43 AM
CHEYENNE's Avatar
CHEYENNE
Default RE: Painting a fender
Is the prep work already done? Do they have to do some body work to it or ust prepping and painting? That makes a difference in cost.
Old Feb 27, 2006 | 04:26 PM
It is red now so i guess some prep will be needed but it doesnt need body work.
Old Feb 27, 2006 | 04:40 PM
bountyhunter's Avatar
bountyhunter
My painter will do a black fender for $85 US.
Old Feb 27, 2006 | 11:05 PM
spartns's Avatar
spartns
You should find that $80-$100 will cover it.
Old Feb 28, 2006 | 02:05 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Also....
The DuPont Super Jet Black matches the HD Vivid Black. That's what I used when I painted the quick detach fairing for my bike.
Generally I will do a black fender for about $90 as long as the fender is in good shape, the existing paint doesn't need any major work, and no rust is involved. That $90 includes sanding / scuffing the fender, a coat of 2-part epoxy sealer, basecoat, 3 coats of clear, and wet sand / buff.
Brian
Old Mar 3, 2006 | 01:37 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I used DBC9700 Dupont black for my 2003 vivid black FLHTPI. perfect match
40 for a pint of paint, 17 for the reducer, had the clear alredy, but a quart of clear is about 30 bucks.
DBC has no shelf life and you can pour the leftover back into the can from the gun.
you may find a jobber who will mix half pints if you ask around.
prep? wipe it down with denatured alcohol, wetsand with 600 wet dry and you are good to go.
figure about an hours labor to paint it if you do the prep work.
see it matches!
Brettfullthrottle
Powdercoat & Paint
Apr 8, 2014 06:19 PM
mattVA
Dyna Parts
Jun 4, 2012 10:31 PM
FBinSoCal
Jan 24, 2012 01:25 PM
TIPN8R
Powdercoat & Paint
Jan 8, 2011 09:58 AM
jambor07
Oct 3, 2008 04:03 PM
