DYNO Numbers for Baggers???
Old Apr 29, 2016 | 05:46 AM
  #5361
Tn.Heritage's Avatar
Tn.Heritage
Originally Posted by TroubledWine
103"
Stage 1 AC
D&D Fat Cat perforated baffle
Andrews 57h
Power Commander 5
With that pipe you should be near 100hp and 115tq, looks like the tuner left a little on the table, your combo is good and I know it's probably a big improvement over stock but it's in the tuner to bring that out. Might need to take it to another tuner somewhere. But if your happy that's all that counts !!
Old Apr 29, 2016 | 05:23 PM
  #5362
Ohiobellboy's Avatar
Ohiobellboy
That's almost identical to the '11 CVO I had with a Fat Cat and tuner. That cam will make up the difference in those 7CID I had over a 103??
Old Apr 29, 2016 | 05:26 PM
  #5363
Tedwilliams09's Avatar
Tedwilliams09
My 107 with those cams hit 125/125...
Old Apr 29, 2016 | 07:38 PM
  #5364
Ohiobellboy
Nice
Old Apr 30, 2016 | 06:25 AM
  #5365
Tn.Heritage
The reason I said that was I had them in my 103 and it did 103hp and 113tq. I still have a 103 but now I'm at 120/120. The 57 is an awesome cam if properly tuned !!
Old Apr 30, 2016 | 09:20 PM
  #5366
Ohiobellboy
Nice. Makes me really think about upgrading the cams in my '15.
Old May 1, 2016 | 12:49 PM
  #5367
harleymike77's Avatar
harleymike77
Default 2014 Ultra Limited - Dyno Sheet
Freshly Dyno'd. You can see the mods in my sig, as follows:
Andrews 57h Cams
Timken bearings
SE Adjustable pushrods
2-1-2 Headpipe
SE Chisel Extreme Billet Air Cleaner
4" Rineharts
S.E.P.S.T.
HP - 91.51
TQ - 106.72
VERY happy camper here.
Old May 1, 2016 | 09:17 PM
  #5368
TroubledWine's Avatar
TroubledWine
I have never seen a dyno graph of a stock head, stock compression 2011-2013 103" with Andrews 57h cams hitting 100hp in SAE correction.
I just noticed you have a 2014. So you have 10.1:1 compression and liquid-cooled vs my 9.6:1 and air cooled. And I went back and looked at your dyno graph from a previous thread and it said 100hp, not 103. So you got 7hp more, on a different dyno, with a half percentage more compression and liquid cooling.
Old May 2, 2016 | 05:57 AM
  #5369
Tn.Heritage
Notice here in this dyno chart the difference between my 2-1-2 set up vs my Wrath 2-n-1 set up, thats where the 103 came in. And it's the same dyno, same tuner, same cam's, just a different exhaust combo. I'm not going to tell you something if I didn't have proof in what I said, sorry but I thought you saw this sheet.
Old May 2, 2016 | 08:44 AM
  #5370
TroubledWine
I meant different dyno as in mine was done in Burlington, NC and yours was done in TN somewhere. I had my Camaro on multiple different dynos and it never once gave the same number. Also, like I said, you have liquid cooled heads running 10.1 to 1 compression. Big difference in stock applications. The Rushmore bikes are routinely making over 100hp cam-only with decent exhaust systems.
