oil question ?????????
Old May 27, 2008 | 04:40 AM
relli's Avatar
relli
Default oil question ?????????
with gas at the prices being what they are and the economy i'mreviewing everything from my phone and cable bill down to the cost of the oil i run. Mobil one and Amsoil are neck and neck in the reports i've read. My question is: if I were to switch to Mobil One would it make adiff if i used the 20/50 auto instaed of the 20/50 motorcycle specific?? both theamsoil and mobil are about 10 bucks a qt but the mobil one at the discount stores is 22 bucks a gallon. id run this in the engine only as i think itb has additives thats not friendly to the clutch.
Old May 27, 2008 | 04:50 AM
jpooch00's Avatar
jpooch00
Default RE: oil question ?????????
My understanding is that motorcycle-specific oils have special additive packages for hotter-running air cooled engines. More phosphorus etc. Also no friction modifiers that would effect clutch performance.
I use Redline 20W60 in my shovel motors with great results. If you consider the longer oil change intervals with the synthetics, the costs just about average out.
Just my $.02
Good luck,
John
Old May 27, 2008 | 04:57 AM
dog155's Avatar
dog155
The advantages using synthetics are many that most people don't realize.Startup lube,less friction= less heat,better mileage,long change intervals,etc.Especially good if you are running a Turbo.
DinoM
Oil Archive (no new posts)
Nov 29, 2017 04:50 PM
jkiser
Oct 12, 2015 08:09 AM
cdlguy
May 18, 2009 07:01 PM
08HD
Sep 9, 2008 11:20 PM
Gadgetech
Aug 19, 2006 01:16 PM
