ENGINE VIBRATION
Old May 27, 2008 | 03:23 PM
BOWLINGDUDE1954's Avatar
BOWLINGDUDE1954
6th Gear
Default ENGINE VIBRATION
i have an 07 ultra with 10k miles on it. 2500 miles ago the engine started shaking real bad at idle. i hade the dealer replace the motor mount and something called the iac? still shaking real bad. does anyone have any idea what the problem could be. my mechanic says it s nothing major but its annoying that i even get a buzzing through the floorboards at speed. i just went round trip to myrtle beach 1700 miles and no mechanical problems, just the vibration. i m idling at 1000 rpm. i even did pipes and a fuel pack with air cleaner and still shaking. i m curious if anyone else has this problem. i m concerned about crank?
[IMG]local://upfiles/62715/6CE4B3D5A7D04A1DAF5A3CA8EC22C6D3.jpg[/IMG]
Old May 27, 2008 | 03:44 PM
Lroberts4's Avatar
Lroberts4
Default RE: ENGINE VIBRATION
Mine has always shaked at idle - they are not a counter-balanced engine, should smooth out nicely a riding rpms, some have had good luck decreasing the vibration by installing the IDS.
Old May 27, 2008 | 04:33 PM
madurodave's Avatar
madurodave
ORIGINAL: Lroberts4
My bike was pretty smooth last year. I added the IDS over the winter. Now it feels like it vibrates more!
I will be checking with the dealer shortly and will let you know what they say.
Old May 27, 2008 | 08:07 PM
BOWLINGDUDE1954
6th Gear
thanks, what is an IDS?
Old May 27, 2008 | 08:33 PM
cirhere2's Avatar
cirhere2
Have the crank checked
Old May 27, 2008 | 08:43 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
Could this be your problem?
https://www.hdforums.com/m_3330649/tm.htm
hth,
Dave
Old May 27, 2008 | 09:00 PM
lp's Avatar
lp
ORIGINAL: madurodave
ORIGINAL: Lroberts4
Belt tension?
lp
Old May 27, 2008 | 09:03 PM
BOWLINGDUDE1954
6th Gear
no because the engine is vibrating like mad in neutral and the belt is not moving.
Old May 27, 2008 | 09:36 PM
scooty's Avatar
scooty
Last year I had a dealer tell me that I needed a front motor mount, so I bought a new H.D (made in China) mount and changed it, well that made things 100% worse you could not stand to ride it so I put the original back on and all is well. There was nothing wrong with the original mount he just thought it was squashed a little.
Old May 28, 2008 | 12:44 AM
HangFire's Avatar
HangFire
My Road King shakes and shimmies at idle. I just figured that's the way it's supposed to be. I think it adds character.
