will they work? (wheels)
Old Feb 28, 2006 | 06:02 PM
4Scott4's Avatar
4Scott4
Default will they work? (wheels)
i have a 97 road king.. i recently found a set of stock spokes off of a 2002 will they work?
Old Feb 28, 2006 | 06:04 PM
MACK's Avatar
MACK
Default RE: will they work? (wheels)
NO THEY WONT. DIFFERENT HUBS DUE TO SEALED BEARINGS WHICH STARTED IN 2000
Old Feb 28, 2006 | 06:05 PM
4Scott4's Avatar
4Scott4
thats what i heard! thanks!
Old Feb 28, 2006 | 06:31 PM
04RoadKing's Avatar
04RoadKing
They are different but I think if you just changed out the spacers it shoud work. I know on my Softail I changed the front wheel to a 80 twisted spoke and they weren't seald bearing's and all I did was change out the spacers and it worked fine. I don't know why the RK wheels would be any different unless it has something to do with the rear pully being a different size. I would think as long as they have the same axle size all you need to do is buy a set of spacers for 2002 model and they would work fine.
Old Feb 28, 2006 | 07:02 PM
100yrfatboy's Avatar
100yrfatboy
I don't think they'll work on either end. In 2000 they did all go to sealed bearings and you would have to swap hubs, but they are 1 piece in harley wheels. I believe the rear went from a 3/4" axle in 2001 to a 1" axle in 2002. Hope this helps.
Rabid1
Jan 13, 2014 05:07 PM
Jackazz
Oct 1, 2012 11:55 AM
Rayvan
Aug 22, 2012 03:34 PM
Tanker2
Mar 28, 2011 04:48 PM
anubisss
Nov 30, 2007 01:55 PM
