Strange problem on UC
Old Jun 1, 2008 | 08:52 PM
hitchhiker2706's Avatar
hitchhiker2706
Default RE: Strange problem on UC
Some good feedback folks,,,gave me some things to discuss with the dealer. Thanks
Old Jun 2, 2008 | 11:56 PM
vickon's Avatar
vickon
I'm experiencing the exact same issues ....'08 EGClassic, Rinehart duals, FuelPak, SE a/f, HD Stage I download.
Only does it when hot and taking offin 1st gear, exactly as described, you gotta over-throttle and it sounds like a "noobie"slipping the clutch.
Almost dropped her making a sharp left from stop..foot down, panic...extra gas and clutch work saved it...8[
Could it be the rear cylinder disable software (due to heat S. Florida)?
I'llkeep monitoring it and take it to the dealer asap for diagnostics and to have the the rear cylinder heat option disabled if possible.
Old Jun 3, 2008 | 12:05 AM
Rocky Rox's Avatar
Rocky Rox
I've seen the same thing happen.
08 RG, SEAC, Rineharts, Stage1 download
Old Jun 3, 2008 | 02:05 AM
DZLDR's Avatar
DZLDR
just food for thought, but since it only happens when the bike is hot, and never when cold, check to see if you have the EITMS enabled. if you do then disable it.
https://www.hdforums.com/upfiles/45117/A4FC3962F1564DD6B2DB1D8E4B584707.jpg
ORIGINAL: hitchhiker2706
Okay problem solvers,,,here's one for ya.
Have an 08 EGUC,,now with 4k. Since new, taking off in first gear occasionally it felt like there was a 900 lb anchor attached to the bike,,not always, just occasionally,,just seemed hard to get it going in first gear. Clutch engages then bike just chugs for a few seconds before coming to life. Other gears fine and runs great. Figured after break in and new pipes, breather, etc at 1k problem would go away. Nope. Took it on long trip to hill country (live in flat Fl) and problem really showed itself, as hills just added to it. Again, only occasionally, and never when cold. Most often when motor is at operating temp or hotter. Easiest way to describe the problem is the way my riding buddy put it- "are you taking off in second gear?"
Anyone have any ideas? Have appt. to take to dealer,,just hoping to get some feedback from the unbiased folks on the forum!
Thanks
Old Jun 3, 2008 | 02:22 AM
thatguy's Avatar
thatguy
The default on the SERT is engine heat management ON.... turn it off in the constants menu.
Old Jun 3, 2008 | 07:12 PM
hitchhiker2706
That's it exactly,,,,love to hear what they tell you when you take it in
Old Jun 3, 2008 | 07:13 PM
hitchhiker2706
Two good ones from DZLDR and thatguy,,,sounds pretty reasonable,,,will pass that on when I take it in ,,,,thanks!
Old Jun 3, 2008 | 07:50 PM
dowork08's Avatar
dowork08
never had the problem with my 08 SG but i do havea PCIII. I do notice the taller gearing though
Old Jun 3, 2008 | 08:05 PM
RoadKing_Al's Avatar
RoadKing_Al
ORIGINAL: cybermunster
That option is only enabled if you ask for it to be enabled. As I was told by the stealer. You are then able to turn it on or off at your discretion.
Old Jun 30, 2008 | 10:13 AM
hitchhiker2706
Update........
&nbsp\\;
Especially for jhill2209 and cybermunster.....
&nbsp\\;
Found a dealer who immediately recognized the problem...said it's the throttle by wire not properly opening the throttle body on occasion.&nbsp\\; Dealer says they were able to "tune it out" with SERT, but didn't know how to handle it with Fuelpak,,,suggested I call V&amp\\;H which I will do and update the post.
&nbsp\\;
&nbsp\\;
