Overloaded? Update!!
Old Jun 3, 2008 | 07:21 PM
GGC's Avatar
GGC
Default Overloaded? Update!!
&nbsp\\;Went to Atlanta this weekend to see Daughter and Grandchildren, Had a great ride up and back,and of course a great time there! Anyway as I pulled into My driveway I was enjoying the music ,so I turned the Ign. Sw. to Acc, Backed bike into it's parking spot turned the Sw off and it stayed on Acc!&nbsp\\; Pulled max fuse,,,Big mistake alarm goes off!! reset it and then put bike in My shop to further investigate,, Found and pulled plug off the siren,,,Big mistake!! Very loud,, reset again take it apart and remove it's battery, Happened to Notice the Siren system was installed backwards(the siren was mounted toward the bikes battery,not faceing outward!) Explains why it was never very loud!&nbsp\\;&nbsp\\; Noticed Wierd smell coming from Ignition Switch So I took it to My local H.Dealer! They looked at it and agread the switch was smoking! Of course I have put lots of Harley light's on the bike so They think I may have overloaded the Switch!
To be continued!
Just got bike back ,,new switch installed, Warrenty covered everything. Not even a mention about lights!
My dealership does great again,, Thanks Big Swamp!! Opelika, Alabama!
Old Jun 3, 2008 | 08:13 PM
HawgriderPa's Avatar
HawgriderPa
Default RE: Overloaded?
can't tell from your pics, but you might consider changing out as many bulbs (turnsignals, brake, tourpack)as you can& replacing them with LEDs.. LEDs only draw 1 watt..
[IMG]local://upfiles/55933/C94F1899312D4ABD830826B66C0D10E8.jpg[/IMG]
Old Jun 3, 2008 | 09:04 PM
GGC's Avatar
GGC
Already done!
Old Jun 3, 2008 | 09:09 PM
ripper43's Avatar
ripper43
Do you have room for any more lightsI think the Stealer may be right........
Old Jun 3, 2008 | 09:25 PM
HawgriderPa
to keep from running amps so much thru the ign switch, you might consider mounting the harley 3 switch unit on the handlebar.. let it control 3 relays.
hardwire from the battery to the feed leg of the relay for the higher current draws (glow rails, lights).. that way the current load going thru the ign switch is only enough current to engage the relay.. I did this with my heated seat and high power driving lights..
Old Jun 4, 2008 | 10:46 AM
OregonRoadKing's Avatar
OregonRoadKing
Separate lines and switches are the safest way to go and they give you more control.
Old Jun 12, 2008 | 02:15 PM
GGC's Avatar
GGC
Fixed, new switch,everything was covered by Warrenty!! Thanks Big Swamp! Opelika, Alabama!
Old Jun 12, 2008 | 04:20 PM
garyhendley's Avatar
garyhendley
dont you have a aux switch ??
Old Jun 12, 2008 | 04:38 PM
GGC's Avatar
GGC
It's an Ultra,,of course it has an aux switch, It was the Ignition switch that was defective.
Ndoggct
Apr 5, 2015 11:09 PM
Lightyear68
Mar 19, 2015 07:31 PM
Dckweed60
Oct 27, 2014 07:38 PM
Turbo Turtle
Sep 3, 2013 10:53 PM
bladeguy
Jul 13, 2009 03:56 PM
