103 vs. 110 big bore
Old Jun 4, 2008 | 03:53 PM
ripper43's Avatar
ripper43
Default RE: 103 vs. 110 big bore
ORIGINAL: TexasRedneck
Wahl, ah kin answer PART of the question - paid $1700 fer the 110" Screamin' Eagle kit last weekend - dealership wuz havin' a sale ta clear old stock.
They're sayin' 22 hrs total on the install......
I've seen whole bikes built in less time.
Old Jun 4, 2008 | 03:59 PM
shekmark's Avatar
shekmark
Do you guys with these engine size upgrades get more vibration than the stock engine. Also, , is the factory stock bottom end strong enough over alot of miles to handle the bigger cubes?
Old Jun 4, 2008 | 04:03 PM
ripper43's Avatar
ripper43
I think anything 110" and over requires some bottom end work.
Old Jun 4, 2008 | 04:36 PM
Dalton's Avatar
Dalton
ORIGINAL: PhilM
ORIGINAL: gmc
The Salt Lake City service manager, Parker, 801-487-4647 went this route and gets over 100 HP and a little more torque but your looking at $7,000.
If you go with 110 your looking a even biger bucks to split the cases, oil coolers, and whatever else they have to do and Parker doesn't think you get your money's worth.
OMG!
For $7k, you better be a helluva lot closer to 150ft/lbs of torque than 100, or you got screwed. I have less than that in my 120.
You can EASILY build a 103 or 107 for less than $3k that will make 120ft/lbs (+/-) of torque for less than $3k ~ if you use the right parts.
+1
Going to 110 requires cases to be split, and case boring. You can easily go to 113 for about the same money. I would re-evaluate what you have done with the 103 and see where you want to go, it will be much more cost effective.
Old Jun 4, 2008 | 05:08 PM
PhilM's Avatar
PhilM
&lt\\;P&gt\\;
ORIGINAL: shekmark &lt\\;/P&gt\\;
&lt\\;P&gt\\;Do you guys with these engine size upgrades get more vibration than the stock engine. Also, , is the factory stock bottom end strong enough over alot of miles to handle the bigger cubes&lt\\;/P&gt\\;
&lt\\;P&gt\\;
&lt\\;/P&gt\\;
&lt\\;P&gt\\;&amp\\;nbsp\\;&lt\\;/P&gt\\;
&lt\\;P&gt\\;No additional vibes on my 120&quot\\;. Actually, it is smoother than stock because it has a crank that was built (including balanced ~ like dalton’s) by the guys @ Darkhorse. Honestly, anything over a 103/107 you really want to give some thought to improving the crank. The 07 / 08 &amp\\;nbsp\\;are prone to &quot\\;sissoring&quot\\; as it is and when you pack a bunch more power in there, it really becomes a situation where the crank can easily become &quot\\;the weakest link&quot\\;. &lt\\;/P&gt\\;
Old Jun 4, 2008 | 06:29 PM
gmc's Avatar
gmc
My only point is that he should upgrade the cams and he should get the performance he need for a lot less $ than going with a 110.&nbsp\\; I should have said a lot more torque, I don't have the actual numbers, but he replace the heads, throtle body, injectors and a lot of other stuff which adds up.&nbsp\\; Those of you who can get 100 HP and 120 lbs of torque for $3000 need to list your parts and who does the install.&nbsp\\; My 103 stage II runs just fine with the Rinehart true duals.&nbsp\\; &nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jun 4, 2008 | 07:20 PM
Ultra007's Avatar
Ultra007
For those who seem to be hard of hearing (or reading).
&nbsp\\;
CAMS, HEADS, HEADS, CAMS and CAMS AND HEADS!!!&nbsp\\; Oh and a SERT or the like.
No need to change intakes or injectors until you get around 110 hp or so with a 103".
100+ hp / 100+ lbs isn't that tough with a 103" IF you match the components and have a good tuner.
Maybe $3000 +/- including exhaust if going from a 96".&nbsp\\; Add about $700 or so if starting with an 88".
And for the SERK question as compared to a "built 95".&nbsp\\; Get those lazy butt CVO cams out of there and work the heads a little and that 95 will be left behind whining and crying.
&nbsp\\;
U
&nbsp\\;
&nbsp\\;
Old Jun 4, 2008 | 07:53 PM
Dalton's Avatar
Dalton
ORIGINAL: gmc
My only point is that he should upgrade the cams and he should get the performance he need for a lot less $ than going with a 110.&nbsp\\;\\\\\\; I should have said a lot more torque, I don't have the actual numbers, but he replace the heads, throtle body, injectors and a lot of other stuff which adds up.&nbsp\\;\\\\\\; Those of you who can get 100 HP and 120 lbs of torque for $3000 need to list your parts and who does the install.&nbsp\\;\\\\\\; My 103 stage II runs just fine with the Rinehart true duals.&nbsp\\;\\\\\\; &nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;
You asked so here is two builds I have done that exceed the 100/100 mark.
&nbsp\\;
03 RKC bored to 95", HTCC Pistons and HTCC Heads, TW5G cams, Rinehart true duals, stock throttle body and injectors, stock lifters and adj. pushrods.&nbsp\\; Tuned with a PCIII.&nbsp\\; 102 hp, 112 tq.&nbsp\\; Cost less exhaust was&nbsp\\;about $2k.&nbsp\\; Work done by me.
&nbsp\\;
07 Ultra bored to 103", HTCC CNC heads, HTCC pistons, Woods TW 400-6 cams, SE 50mm throttle body, adj pushrods, stock lifters,&nbsp\\;RB Racing Blackhole 2-1 exhaust, tuned with a DTT TCFI IID.&nbsp\\; 120hp, 121tq at peak performance tune, 112hp, 118 tq tuned for everyday riding.&nbsp\\; Cost,less exhaust and DTT was just over $2k, work done by me.
&nbsp\\;
The 120 I am now riding is a Headquarters top end (heads, cams, pistons, lifters), a Jims Crank reworked by Darkhorse and cases bored by same.&nbsp\\; Total cost for just the engine build is just over $5k, again, assembly and build done by me.&nbsp\\; I have not had mine dynoed, but PhilM is almost 130 hp and 157tq and my build is very similar, only differnce is exhaust and throttle body.
&nbsp\\;
You can build a reliable street stormer using Headquarters matched components for a 103 or 107 for about $3500 which would include labor and produce hp and tq in the 110 to 120 range depending on cams and exhaust used.&nbsp\\; For $7k you should be able to have a complete 120 asembled and installed, again minus other peripherals like exhaust and tuning system.
&nbsp\\;
After building the HD builds, and a previous T-Mann build, I have learned the key is matched components and headwork done specifically to match the piston and cams.&nbsp\\; Headquarters components will get you there with repeatable, consistent results.&nbsp\\;
Old Jun 4, 2008 | 08:26 PM
Tinkermc's Avatar
Tinkermc
I ride with 2 guys a lot, 1st guy has Ultra with 110, 2nd guy rides a Street Gliude w/103. I have standard Ultra motor with Rhineharts and a tuner with auto learn. The 103 wins every time from dead start, rolling start or top end runs. Only thing we see to the 110 is he burns a lot more fuel than we do.&nbsp\\;
Old Jun 4, 2008 | 08:41 PM
Harleypingman's Avatar
Harleypingman
For those interested in HD's SE line of products, here is a link to the on-line catalog, including dyno charts for a variety of SE builds:
&nbsp\\;
http://www.harley-davidson.com/en_US...SE_001_031.pdf
