Hand grip install query?
Old Jun 4, 2008 | 06:02 PM
Danall's Avatar
Danall
Default RE: Hand grip install query?
Now, if you want to change the handle bars and save the grips to reinstall, can you remove them without damage?&nbsp\\; And, if so, how?
Thanks.
Old Jun 5, 2008 | 08:09 AM
RD GLD's Avatar
RD GLD
ORIGINAL: Danall
Now, if you want to change the handle bars and save the grips to reinstall, can you remove them without damage?&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; And, if so, how?
Thanks.
The ones he is putting on that do not require glue he can. Some times the ones with glue will come off if you use a hairdryer and warm it up and then use an air hose and blow around the grip and handlebar. Should come off.
Old Jun 5, 2008 | 08:32 AM
BuddyinStL's Avatar
BuddyinStL
Not a problem. I haven't ever installed the glueless grips, but you are right that the grips fit under the housing. I have an 03 with Kuryaken grips so my instructions were for that model year.
Old Jun 5, 2008 | 08:59 AM
FLHT's Avatar
FLHT
Isnt there a switch on the clutch side now (07 and 08) that has to be delt with?
Old Jun 6, 2008 | 10:37 AM
Peppa1's Avatar
Peppa1
Nothing to worry about or deal with on clutch side.
Old Jun 6, 2008 | 11:19 AM
08HD's Avatar
08HD
Did the installation of my hand grips........WoW! easy as cutting pie. the 08 is so easy with the new fly by wire throttle you simply slide of the old one and put on the new one. The left side actually takes longer to do because you have to unstick the old grip. I must say I have not had dealer install any of my accessories thus far so I am saving money if I can do it myself!!! [sm=yeahsmile.gif]
WVDevil
May 15, 2015 08:38 PM
mike_oh
Apr 15, 2012 10:11 PM
blackpullet
Mar 17, 2011 06:24 AM
1200cc
Feb 7, 2007 07:15 PM
Dsanchez
Mar 3, 2006 06:16 PM
