Well, I finally went thru all the selections/options on building up my stock TC88 and this is the way I'm going.
I deliver the bike on the 11th and should have it back by the 15th so I can ride my tiny 500 mi break-in (at various speeds/loads) and take her back in for my final SERT Map.
SE 95" Cylinders
SE HTCC Piston Kit
SE HTCC EFI Manifold (D-Style to match the heads)
SE HTCC Heads
SE EFI Race Tuner
SE Clutch springs
LITE Touch kit (for smoother clutch for the beefier springs)
SE Adjustable Pushrods
S&S 570G Cams/Gears/bearings Kit
Rinehart TRUE DUALs
Kuryakyn Hyper-Charger Pro
Congratulations,
What made you chose the SS cams when everything else is SE?
Screamin Chicken doesn't make GEAR cams. Only Chain. What is interesting to me is the +/- tolerance differences between them based on the same Exhaust duration and TDC degrees/angles. For gear's there in the .003 range.. for Chain they are in the .030 range.. 30 thousands may not sound like much.. but on an engine with performance head/valves it would.
Sound's like you can hardly wait. I know that you will enjoy the extra power. And what tork it is realy fun cruzing the hills. Crank it a little for me.
