Breaking her in
Old Jun 5, 2008 | 09:46 AM
Boxer 6's Avatar
Boxer 6
Default Breaking her in
How did you guys break in your bikes?&nbsp\\; Mostly city riding, highway riding or a combonation of both.&nbsp\\; I have about 300 miles on my 08 SG and I am thinking about making a run up to Vermont which is mostly highway.&nbsp\\; I think varying the RPM's is good to do, but on the highway it may be hard to accomplish that task.&nbsp\\; Any comments on this topic?&nbsp\\; Thanks!!
&nbsp\\;
Mark
Old Jun 5, 2008 | 09:50 AM
madurodave's Avatar
madurodave
Default RE: Breaking her in
I tried to vary the speeds as much as I could. I avoided lugging (as you should anyway) and kept speeds in gears to recommended speeds.
&nbsp\\;
The first few longer rides I took I rode backroads mainly. I rode from my house to Winnipesaukee using backroads which was fun. If you can, keep the highway riding to a minimum and mix in plenty of backroads.
&nbsp\\;
Good luck!
Old Jun 5, 2008 | 10:17 AM
Bryan TTM's Avatar
Bryan TTM
ride the **** out of it.....rings are seated within the first 50 miles....forget what the moco says, break it in like your gonna ride it
Old Jun 5, 2008 | 10:21 AM
Zimbob's Avatar
Zimbob
Broke mine in like it was stolen. She runs great too.
Old Jun 5, 2008 | 10:26 AM
Donnylee's Avatar
Donnylee
Just ride it normal....I would recommend an oil change at 1000 Miles
Old Jun 5, 2008 | 10:36 AM
Big Peter's Avatar
Big Peter
Found this on the S&amp\\;S site
&nbsp\\;
Well, that should do it. To summarize what we've talked about, here is the sequence we recommend for "proper engine break-in":
[ol][*]Fit the pistons on the tight side of the recommended fitting range.[*]Use good general engine assembly habits, keeping in mind the earlier points we discussed, including ignition timing, carburetion and maintenance.[*]On initial engine startup, don't just sit and idle the motor while you admire your work or tinker with minor adjustments. Heat buildup at this point can be excessive.[*]The first 50 miles are the most critical for new rings and piston break-in. Most engine damage will initially occur during this period. Remember that if proper ring seating does not take place, the resultant blow-by will set the stage for possible future damage because there won't be sufficient oil on the cylinder walls for proper lubrication. So keep the heat down by not exceeding 2500 rpm. And vary the speed.[*]The next 500 miles should be spent running the engine no faster than 3500 rpm or about 50-55 mph. Do not lug the engine and continue to vary the speed.[*]Up to 1000 miles, the speed can be run up to 60 to 70. Continue to run the engine at different speeds including the lower 4~5 mph ranges. When the 1000 mile mark is reached, most Evolution engines should be broken in. Evolution engines tend to run slightly cooler\\; and therefore do not require as long a break-in period as earlier engines using iron cylinders.[*]From 1000 to 2000 miles basically use the same procedures as before, but you can be a little more liberal with the rpm range. Avoid overheating the engine and putting any hard strain on it (drag racing, trailer towing, sidecar operation).[*]2000 miles and up, have fun! Just remember, while our recommendations sound good and normally work, there is no cook book formula for proper engine break-in. Common sense and knowing what is really happening inside those cylinders are the best tools for break-in. We at S&amp\\;S realize that after riding a stocker, a Sidewinder or Stroker feels very strong and the temptation to "turn it on" is overwhelming, even hard to resist. If this urge to run the engine hard overcomes you before engine break-in is completed, extensive engine damage can result. The obvious way to help prevent sticking the pistons is to give them a loose fit which naturally will detract somewhat from piston life and quiet running. This may be the best route to follow for those riders who want to go fast immediately. Keep in mind though, even loosely fit pistons should be allowed at least 50 to 100 miles of break-in for ring seating purposes. And, pistons and rings fit in this manner will have to be changed more frequently.[/ol]
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; Good luck,
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; Peter
Old Jun 5, 2008 | 11:07 AM
iclick's Avatar
iclick
ORIGINAL: madurodave
Good luck!
+1 on this recommendation, the emphasis being on varying the speeds.&nbsp\\; Play with the cruise control if you wish, but don't leave it on long! &nbsp\\; Resist advise to "break it in hard" or "Ride it like you stole it." &nbsp\\; I've been fooling with cars and MC's for 45 years and have never known a manufacturer to recommend this procedure.&nbsp\\; OTOH, you don't want to ride it so easily that the rings fail to seat.&nbsp\\; Vary the speeds and do some moderate acceleration and deceleration, but just keep it civil for the first 2-3k, gradually increasing speed and load.
This is just my opinion, but I always change the oil and filter at 500 miles, then again at 2k.&nbsp\\; At 5k I start a regimen of oil changes every 5k.&nbsp\\; I used fossil engine oil (Castrol GTX or HD 360 20w50 are good break-in oils) for the first change, switching to synthetic at 2k.
Old Jun 5, 2008 | 11:29 AM
BEAST's Avatar
BEAST
I agree with Bryon. Some people put way too much into it.
Old Jun 5, 2008 | 12:00 PM
DoomBuggy's Avatar
DoomBuggy
I've also been building engines since the late '60s and for my new '08 Ultra I followed a simple procedure which lines up with that posted above as well as with what the dealer told me.&nbsp\\; First 50 miles keep the rpms under 3500 and speeds under 50mph ( in case something falls off the bike, like an axle nut&nbsp\\.&nbsp\\; From 50 to 100 moderate speeds, not letting the bike get too hot. ( no stop and go traffic ).&nbsp\\; 100 to 1000 keep the rpms under 4000 and vary conditions and RPM.&nbsp\\; Some highway, so local, just don't set at a single speed for more then about 5 minutes at a time.&nbsp\\; After a grand change the oil and the motor is pretty much set.
&nbsp\\;
I&nbsp\\;do not ride 2 up till I have at least 300 on the motor.&nbsp\\;
&nbsp\\;
The above is jmho, but I've always ended up with good compression on my motors and never had one fail unless I missed a shift at the track.
&nbsp\\;
-Harry
Old Jun 5, 2008 | 12:10 PM
BCguy's Avatar
BCguy
Lots of good advice here. I think moderation is the key - not too easy and not too hard for the breakin period. You need to work the engine and drivetrain some to get everything to mate properly but you don't want to overstress components that are still fitting themselves together. Lots of variations in speed - accelerate and decelerate, shift thru the gears, no lugging, no over revving, no extended idleing (sp?). You get the picture. It really ain't rocket science.
I've used this philosophy with many bikes over many years and never had a problem. &nbsp\\;
