Really Dumb Question
Old Jun 6, 2008 | 09:38 PM
scooter34's Avatar
scooter34
Default Really Dumb Question
I have an 08 Flhtc, and how do I know if I have ABS on my bike, VIN etc..... Thanks
Old Jun 6, 2008 | 09:50 PM
Windup08's Avatar
Windup08
Default RE: Really Dumb Question
One easy way to tell is there is an extra wire going to each wheel, and above the left front brake caliper there will be a little black clip to hold the wire, it will say ABS on the clip. &nbsp\\;
Old Jun 6, 2008 | 09:56 PM
Windup08's Avatar
Windup08
Also, if you can't find the clip pull off the right side cover, the ABS controller fills almost all the space under that cover.&nbsp\\;\\\\\\; If you have lots of free space there you probably don't have it.
Old Jun 6, 2008 | 09:58 PM
TNTHarley's Avatar
TNTHarley
If you have it, a light designating ABS comes on when you turn the ignition on.
Old Jun 6, 2008 | 10:03 PM
badinfluence63's Avatar
badinfluence63
If you bought it new it will be in the paperwork.
Old Jun 6, 2008 | 11:02 PM
waterboyjack's Avatar
waterboyjack
And the real simple way...... follow your front brake hose from the master cylinder, if it goes straight to the caliper, you ain't got no ABS man
Old Jun 6, 2008 | 11:08 PM
HRLYSG's Avatar
HRLYSG
Old Jun 7, 2008 | 05:44 AM
quikbike's Avatar
quikbike
Look at the neck. Two lines running front to back then you got ABS. Seems like the 900 out of your pocket would have told you already
Old Jun 7, 2008 | 06:13 AM
100thRK's Avatar
100thRK
Does it have brembro brake calipers?&nbsp\\; If so it has ABS!
Old Jun 7, 2008 | 06:35 AM
spence222's Avatar
spence222
&nbsp\\;Accelerate to 60 mph......stomp on your rear brake....you'll know then....
