i want to be sure before i try, \\; The Emblem on rear fender of a Roadglide, \\; can that be removed useing a blow dryer? without maring the \\; paint? \\; thanks in advance \\; Also has anyone Moved the plate lower? if so \\; can you advise, your method, thanks
You should be able to remove it with some heat from a hair dryer and dental floss/fishing lineit's a stick onwithout paint damage since the same technique works well for removing tank badges without paint damage.
J&\\;P sells a metal license plate mounting plate, as does Softbrake for relocating the plate below the tail lightit uses the bolts that attach the turn signal bracket to the fender. \\; Haven't used either productwent with HD's SG kit. \\; You will probably need to buy a new tail light lens with the clear on the bottom to light the plate, and something to cover/fill the bolt holes in the chrome fender strut bar.
Good luck with your project.
