Hardbag problem
Old Jun 13, 2008 | 11:11 PM
jcbpa's Avatar
jcbpa
Default Hardbag problem
Trying to install the hardbags on my FLHRC, moved the brackets,&nbsp\\;no dice.&nbsp\\; what is the key to this?
Old Jun 13, 2008 | 11:47 PM
Steelknee57's Avatar
Steelknee57
Default RE: Hardbag problem
Loosen the brackets, you'll have to play with them a bit, but it'll work. Don't force it, you'll bend the pins. Be patient, it'll work......That's what I learned from doing my '04 FLHRS a month ago.
Old Jun 15, 2008 | 04:57 AM
jcbpa's Avatar
jcbpa
I've had the pins almost off! [:@][:@]&nbsp\\; this is crazy.
Old Jun 15, 2008 | 06:20 AM
masterblaster's Avatar
masterblaster
you need to loosen the brackets and turn them with your hand til alignment happens then tighten them in place. play with it a little until you get it right.
Old Jun 15, 2008 | 06:38 AM
dcountryboy's Avatar
dcountryboy
There is spacer I think on the back brackets that is only used with the leather bags .It has to be removed for the hard bags , have you done that?
Old Jun 15, 2008 | 06:54 AM
masterblaster
I did not know that about the spacer, I will remover today and see alignment, no wonder I had such a hard time getting them on.
Old Jun 15, 2008 | 07:05 AM
jcbpa's Avatar
jcbpa
Wow!&nbsp\\; Hope that's it!!!
DGRF250
Dec 30, 2013 09:09 PM
schumacher
Aug 1, 2008 12:31 AM
schumacher
Jul 28, 2008 07:08 PM
1986FXST
EVO
Jul 6, 2008 03:46 PM
Jonny Cannon
Jun 24, 2008 05:05 PM
