Speedometer vs GPS - Can speedo be recalced?
Old Jun 16, 2008 | 02:47 PM
rwagon57's Avatar
rwagon57
Default RE: Speedometer vs GPS - Can speedo be recalced?
My 2007 Ultra speedometer reads about 5% fast\\; i.e., 80 mph indicated is about 76 mph actual.&nbsp\\; I believe this to be fairly common on many bikes including Euro and Jap metrics based on test reports in Motorcycle Consumer News.
Old Jun 16, 2008 | 02:51 PM
huffhuff's Avatar
huffhuff
GPS is not accurate to an exact point.&nbsp\\; Generally they are accurate to within 30 feet, that can account for the difference.&nbsp\\; the speedo in my Titan is faster than my GPS by about 2 mph.
Old Jun 16, 2008 | 03:05 PM
txfxstrider's Avatar
txfxstrider
I asked at the dealership about recalibrating or replacing my speedo under warranty on my 07 RK because I thought it was about 4-5mph fast. I was told anything within 5mph is within standards. I'm not sure whose standards besides HD.
Old Jun 16, 2008 | 03:16 PM
mapman's Avatar
mapman
ORIGINAL: txfxstrider
When I take mine in for the next service, I'll tell them it is 6 mph off and see what they say.[&:]
Old Jun 16, 2008 | 03:20 PM
Phurion's Avatar
Phurion
Pretty common in the Kawi cruiser community as well. Seems all Vulcans report about 5% faster on the speedo than actual.
Old Jun 16, 2008 | 04:46 PM
adlerx's Avatar
adlerx
Dakota digital makes a module, runs just under $100 depending on where you order it... Works great but jury still out on whether it is compatible with 08 tourers
Old Jun 16, 2008 | 05:50 PM
FXSTDSE2's Avatar
FXSTDSE2
The only thing that I drive that matches the GPS is my 95 Dodge Dakota 4X4. Everything else in general, The speebo reads faster than actual speed.&nbsp\\;I looked into this on the auto end some years ago and the OE is allowed +or- some %. All the cars I have worked on are typically off around 3%. Some as high as&nbsp\\;5. My 02 is 2% and my 04 is 6% both read fast.
Old Jun 16, 2008 | 05:58 PM
zapps's Avatar
zapps
My 2008 Ultra is also off about 5 MPH at 70. Not only is the speed off that much but also the odometer also reads more miles on the bike than the GPS. On a tank of gas, the GPS reads about 5-6 miles less than the odometer on the bike. I had a 2001 Gold Wing and it was also off about the same amount. Must be a bike thing.
Zapps
2008 Ultra
Old Jun 16, 2008 | 06:18 PM
Wecroft's Avatar
Wecroft
The only bike I've found to be dead on with the GPS reading is my buddy's Screaming Eagle Fat Boy. Maybe the CVO uses calibrated speedos and the rest of us get seconds. Every roadside radar I've passed has&nbsp\\;read the same as the GPS. Even my Dodge truck is off by 4mph at 70.
&nbsp\\;
By the way, the refresh rate for Garmin units is&nbsp\\;once per second continuous, so don't count on&nbsp\\;lag time as being the culprit.
Old Jun 16, 2008 | 06:37 PM
HDUltraRider's Avatar
HDUltraRider
Had the same problem with my 04 Sportster, was about 5 MPH under and also over stating milage.&nbsp\\; After months of back and forth with the dealer HD come out with a service notice and a hot flash that fixed the problem.&nbsp\\; Might be the same issue I would speak to the Dealer.
