Speedometer vs GPS - Can speedo be recalced?
Old Jun 16, 2008 | 01:02 PM
mapman's Avatar
mapman
Default Speedometer vs GPS - Can speedo be recalced?
So ... with my new GPS and a long trip this last weekend, I noticed that my speedometer reads different than my GPS.
The faster I go, the more discrepancy there is.
When the GPS shows 75 mph, the speedo shows 80 ... arg ...
&nbsp\\;
Can speedos be re-calculated? or am I stuck with that?[:@]
Old Jun 16, 2008 | 01:08 PM
MackAttack's Avatar
MackAttack
Default RE: Speedometer vs GPS - Can speedo be recalced?
I noticed the same thing. I just got a Garmin Zumo and when my 2008 Ultra Classic says 75 mph, the Garmin reads 70 mph. At 64 mph and the Ultra, Garmin reads 60.
I'm going to ask the same thing when I go in this week to the dealer.
Old Jun 16, 2008 | 01:11 PM
sj5611's Avatar
sj5611
&nbsp\\;I have noticed the same thing with my 2008 ultra.&nbsp\\;
Old Jun 16, 2008 | 01:13 PM
rjmac53's Avatar
rjmac53
As far as I know the speedo reads what the speedo reads - no adjustments
Old Jun 16, 2008 | 01:23 PM
petemac's Avatar
petemac
I'm guessing this is a lag in the speedo cable compared to the GPS getting the speed off the sat. Get established at a cruise speed and then see what the difference is. I've done this and the the speedo and gps are within about 1 mph of each other. But when I accelerate/decelerate, there is a much bigger difference is speed.
Old Jun 16, 2008 | 01:25 PM
stro1965's Avatar
stro1965
ORIGINAL: petemac
&nbsp\\;
True, but it's usually the GPS that lags about a second behind.
Old Jun 16, 2008 | 01:29 PM
mapman's Avatar
mapman
ORIGINAL: petemac
My test was done by setting the cruise control for a number of miles (and miles and miles). Even off cruise, I got the same results.
It had nothing to do with acceleration (up or down).
Thanks for the hint, but there is actually quite a discrepancy at the higher speeds.
I hope the speedo can be recalculated.[&:]If anyone know for sure. Let us know. Thanks!
petemac's Avatar
petemac
Hmmmm......that was my best guess.&nbsp\\; &nbsp\\;
&nbsp\\;
Maybe.........the refresh rate on the gps isn't that fast. I&nbsp\\;know on aviation gps's they have a pretty fast refresh rate.&nbsp\\;
&nbsp\\;
If that doesn't do it, I'm out of guesses.&nbsp\\;&nbsp\\; &nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
ORIGINAL: stro1965
ORIGINAL: petemac
&nbsp\\;\\\\\\;
Old Jun 16, 2008 | 02:27 PM
MackAttack's Avatar
MackAttack
There were four of us on a trip last week. Two of us had 2008 Ultra Classics, and the others bikes were both 2006s. The 2006s read faster and about the same as the GPS. Also, we went thru a radar warning sign that tells you the speed you are traveling. It read slower. Also tested it with cruise control and the 2008s read slower.
I definitely believe the problem is with the 2008s at least in our group.
Old Jun 16, 2008 | 02:43 PM
Neckball's Avatar
Neckball
my 2005 speedo reads 2.5-3 mph faster than the GPS shopws.&nbsp\\; I go by the speedo, helps to keep me from getting tickets.
