MASTER CYL LEAK?
Old Jun 18, 2008 | 10:33 AM
FEAR's Avatar
FEAR
Default MASTER CYL LEAK?
AFTER I PUT MY APES ON, I NOTICED FRONT BRAKES DIDNT WORK AS WELL, KINDA SPONGY, AS I PUT ABOUT 200 MILES ON IT, ITS GOT BETTER, BUT I NOTICED A DRIP OF BRAKE FLUID ON TH EBOTTOM OF THE MASTER, I WIPED IT OFF AND RODE SOME MORE, AND IT CAME BACK.&nbsp\\; THE BANJO FITTING IS DRY.&nbsp\\; I THINK IT IS COMING FROM THE SEAL ON THE COVER FOR THE RES.&nbsp\\; IS THIS A COMMON PLACE FOR IT TO LEAK FROM?&nbsp\\; I TOOK ITOFF AN RE-TIGHTENED IT, BUT STILL SEEMS TO BE LEAKING, BUT THE FEEL IN THE LEVER IS GETTIGN A LITTLE BETTER
&nbsp\\;
ANY IDEAS?
Old Jun 18, 2008 | 11:21 AM
phillaf65's Avatar
phillaf65
Default RE: MASTER CYL LEAK?
I had the same problem.&nbsp\\; I too took off the cover, checked out the gasket and closed it up.&nbsp\\; It still leeked.&nbsp\\; I brought it into the dealer, it was still under warranty, and they replaced the gasket.&nbsp\\; Apparently it got crushed when I had it for the 1000 mile service at a different dealership.&nbsp\\; It took 10 days to get the bike back waiting for the part, but at least it got fixed.&nbsp\\; Good Luck.
Old Jun 18, 2008 | 11:24 AM
07RoadHawg's Avatar
07RoadHawg
ORIGINAL: phillaf65
I had the same problem.&nbsp\\;\\\\\\; I too took off the cover, checked out the gasket and closed it up.&nbsp\\;\\\\\\; It still leeked.&nbsp\\;\\\\\\; I brought it into the dealer, it was still under warranty, and they replaced the gasket.&nbsp\\;\\\\\\; Apparently it got crushed when I had it for the 1000 mile service at a different dealership.&nbsp\\;\\\\\\; It took 10 days to get the bike back waiting for the part, but at least it got fixed.&nbsp\\;\\\\\\; Good Luck.
&nbsp\\;
Same here.&nbsp\\; Dealer overtightened and had to be replaced.&nbsp\\; Guess they are pretty fragile.&nbsp\\; Anyway, lesson learned... Do my own service from now on.
Old Jun 18, 2008 | 11:41 AM
FEAR's Avatar
FEAR
The gasket shouldnt contribute to the mush feel though, should it?&nbsp\\; i called dealer, they have them in stock, so for 8 bucks i am gonna try one i think, and re bleed the brakes.&nbsp\\;&nbsp\\; wich caliper gets bled first, the left or the right or does it matter?
Old Jun 18, 2008 | 11:45 AM
FEAR's Avatar
FEAR
ohh and thanks for the help
Old Jun 18, 2008 | 11:50 AM
07RoadHawg's Avatar
07RoadHawg
Not sure that it matters which one first.&nbsp\\; I think I did my right one first just because I was standing there filling the master cylinder with fluid.&nbsp\\; And you are right about the gasket.&nbsp\\; In my experience, only bubbles (or a weak brake line) should cause a spongy feel.&nbsp\\; I had good firm pressure on the lever with the lid off once the air was out of the caliper.
Old Jun 18, 2008 | 07:03 PM
FEAR's Avatar
FEAR
SO I CAHNGED THE FLUID THAT WAS IN THE MASTER WITH SOME GOOD DOT 4 RBF RACING BRAKE FLUID, AND BLED AND THE FEEL IS A LITTLE BETTER, RAINIGN OUT SO I WILL TEST WHEN ITS DRY OUT.
THE GASKET I GOT FROM THE DEALER WAS A LITTLE DIFFERENT FROM THE ONE I TOOL OF, SO WE'LL SEE IF IT ENDS UP LEAKING OR NOT
Old Jun 19, 2008 | 02:00 AM
Big Peter's Avatar
Big Peter
ORIGINAL: FEAR
AFTER I PUT MY APES ON, I NOTICED FRONT BRAKES DIDNT WORK AS WELL, KINDA SPONGY, AS I PUT ABOUT 200 MILES ON IT, ITS GOT BETTER, BUT I NOTICED A DRIP OF BRAKE FLUID ON TH EBOTTOM OF THE MASTER, I WIPED IT OFF AND RODE SOME MORE, AND IT CAME BACK.&nbsp\\;\\\\\\; THE BANJO FITTING IS DRY.&nbsp\\;\\\\\\; I THINK IT IS COMING FROM THE SEAL ON THE COVER FOR THE RES.&nbsp\\;\\\\\\; IS THIS A COMMON PLACE FOR IT TO LEAK FROM?&nbsp\\;\\\\\\; I TOOK ITOFF AN RE-TIGHTENED IT, BUT STILL SEEMS TO BE LEAKING, BUT THE FEEL IN THE LEVER IS GETTIGN A LITTLE BETTER
&nbsp\\;\\\\\\;
ANY IDEAS?
&nbsp\\;
It's very important not to over tighten the
screws on the cover.
The leak can also come from a warped O-ring
on the piston inside master cylinder.
&nbsp\\;
Peter
Old Jun 19, 2008 | 09:07 AM
FEAR's Avatar
FEAR
I just took&nbsp\\;it for a quick 5 mile test ride, stopped 10x better than before and no evidence of a leak out of the new cover gasket, so i think i'm all good now
merman
Screamin Eagle CVO Models
Mar 1, 2018 01:59 PM
w2willi
Sep 17, 2013 01:43 PM
jay72
Aug 25, 2013 04:48 PM
Louie Champan
May 7, 2012 12:06 PM
Rickr01
Oct 11, 2011 06:40 PM
