How to increase mpg in a bagger
Old Jun 20, 2008 | 10:13 PM
Rollon's Avatar
Rollon
Default RE: How to increase mpg in a bagger
06 UC around country back roads (55-60mph) 38-42.&nbsp\\; ON interstate 75-80 mph = 36-34!!!!!
Old Jun 20, 2008 | 10:15 PM
Rollon's Avatar
Rollon
Oh yea, i have Stage 1 with screaming eagle pipes..... Love them pipes..
Old Jun 20, 2008 | 10:38 PM
Ultra110's Avatar
Ultra110
Just my $.02 110" rineharts SERT and I ride hard i get low 40 @ 80 mph right around 220 -250 miles to tank. This is on a 08 Ultra 2 up 50% of the time
Old Jun 20, 2008 | 10:51 PM
biggrantwilliam's Avatar
biggrantwilliam
If you cant afford the ga$$ you cant afford the scooter[:@]
Old Jun 21, 2008 | 01:40 PM
glens's Avatar
glens
ORIGINAL: hdwally
I cannot tell you why, but, I have been told the TC88s run best at approximately 3000rpm.
That has helped my gas mileage. Maybe has to do with torque or not lugging the engine?
It is all about throttle pressure, nothing more. Whatever gear allows the smallest throttle opening for the conditions is the most economical to use. If you cruise at the peak torque rpm you will use the least amount of throttle.
Years ago I worked with a guy who drove a little Toyota pickup to work. He would consistently drive 45 mph about 30 miles down the highway to work. I would pass him every day on the way in. Once I asked him what gear he used and he told me 5th. I suggested he try a couple of trips in 4th to see what would happen. He reported he got better mileage. It does not make much immediate sense that a higher engine speed could make for better mileage. It all depends on where the torque peak is.
Old Jun 21, 2008 | 03:04 PM
EG Ultra Classic's Avatar
EG Ultra Classic
I don't get that. If what you say were true, then why ever shift up to higher gears if you want fuel mileage just bang away in 3rd or&nbsp\\;4th gear, instead of up shifting, dropping r's into the overdrive&nbsp\\;6th.
&nbsp\\;
With my&nbsp\\;bone stock '08 Ultra, and loaded highway mileage,&nbsp\\;the cruise set at 65, I get&nbsp\\;38 to&nbsp\\;40 using exclusively E-10 ethanol blended fuel. Short hops around town where I use the gears and rarely get to overdrive36-38 mpg&nbsp\\;mileage. I believe my Ultra gets the best mileage if you keep the r's around 2200, and stay in 6th gear on the highway. It sounds best around 3k on up. Ya pay to play. It takes Horsepower to play, and fuel makes horsepower. Just a law of nature.
Old Jun 21, 2008 | 03:08 PM
glideridemike's Avatar
glideridemike
just sayin......my '03 WG is gettin just over 50 mpg.......just sayin.......thats for the past 3 tanks........just sayin.......
Old Jun 21, 2008 | 04:34 PM
glens's Avatar
glens
ORIGINAL: EG Ultra Classic
I don't get that. If what you say were true, then why ever shift up to higher gears if you want fuel mileage just bang away in 3rd or 4th gear, instead of up shifting, dropping r's into the overdrive 6th.
First, it must be stated that 6th is not an overdrive. It merely bypasses the transmission, thus bypassing any gear reduction (following the primary reduction, naturally), thus is the textbook example of a one-to-one ratio.
If at any road speed you have the choice of two adjacent gears to use, the one which requires less throttle pressure (throttle opening) will yield the better mileage. If your torque peak was at 9,000 rpm then I guess you would be smarter to use a gear that kept you somewhere below that engine speed, but even if the engine is turning more revs in a lower gear it is still quite likely it would yield better use of the fuel than when using the lower gear ratio (higher gear).
Even though I know everything I have said in this thread to be complete and utter truth, you will rarely see me using 5th anywhere above 60 mph. I would not mind getting somewhat better mileage, but I much prefer the better experience if I have to choose.
Old Jun 21, 2008 | 05:05 PM
iclick's Avatar
iclick
My mileage varies greatly depending on conditions, and it goes like this:
Backroads, 55-60mph, few cold starts, little stop-and-go: 50mpg
65mph: 47mpg
Interstate speeds (70-75mph), minimal headwind: 45mpg
Interstate, strong headwind (20mph): 40-42mpg
City, numerous cold starts: 38-40mpg
I have a PCIII with Fuel Moto map, Rush mufflers with Fuel Moto custom baffles, and Fuel Moto AC. The PCIII is tweaked in the cruise range for mileage.
Old Jun 22, 2008 | 07:11 AM
mchildree's Avatar
mchildree
iClick, I was reading another mileage thread or two, and you'd posted what seemed to be a .jpg of your maps before and after tweaking. For some reason, I'm not able to see that .jpg..... Any chance you could repost it, or email it to me?
I wanna tweak mine too, and I'd like to see the ranges where you made changes.
