04 radio/cd player problem
Old Jun 22, 2008 | 07:34 AM
crashbike310's Avatar
crashbike310
Default 04 radio/cd player problem
I went for a ride a few days ago and everything was fine.&nbsp\\; I rolled up to pay a toll, paid, and went to turn the volume up on my factory 04 RG CD/ AM/ FM radio.&nbsp\\; Nothing.&nbsp\\; The volume is stuck all the way down in the CD mode.&nbsp\\; So now I have a CD playing that I can not hear, change the volume, change the track number, mode, or eject.&nbsp\\;
Anyone else ever have this problem.
Old Jun 22, 2008 | 08:21 AM
kyote's Avatar
kyote
Default RE: 04 radio/cd player problem
Try disconnecting the battery for a few seconds......that should do a reset to the radio....I may be wrong..but can't hurt to try....
Old Jun 22, 2008 | 09:13 AM
KY HDRider's Avatar
KY HDRider
I had one of the handlebar controls for the radio that shorted\\; it was always on.&nbsp\\; That caused the radio to lock up, it would not respond to any input.&nbsp\\; I found the switch was bad, replaced it and then all was OK again.&nbsp\\; You can unplug the wire harness from the switches one side at a time, and then try to eject the CD as a test.&nbsp\\; Good luck.
04Ultra
Old Jun 23, 2008 | 09:02 AM
crashbike310
Thanks guys.
I'll give it a try
Old Jun 24, 2008 | 01:31 PM
crashbike310
Tried the battery disconnect &nbsp\\; Not so much
I took apart the front fairing and disconnected the switches for each handlebar to see if it sorted.&nbsp\\; That worked.&nbsp\\; The right side switch shorted.&nbsp\\; I reconnected the switch and it works again.&nbsp\\; We will see for how long.&nbsp\\;
Old Jun 24, 2008 | 01:36 PM
kyote's Avatar
kyote
Cool...at least you found the problem.....
sdharon
May 6, 2017 10:30 AM
hog8461
Sep 11, 2013 04:15 PM
SharkBite
Oct 1, 2009 05:11 PM
FFeric
Apr 1, 2009 04:55 AM
Harleynole
Mar 24, 2008 11:17 AM
