Miles on TC 88
Old Jun 22, 2008 | 08:33 PM
Grayhawk's Avatar
Grayhawk
Default Miles on TC 88
I currently have 63,000 miles on my 05 ultra without ever having the cam bearings replaced.&nbsp\\; Bike Still runs excellent.&nbsp\\; How many miles has anyone got without changing the cams or without having the motor rebuilt?
Old Jun 22, 2008 | 08:44 PM
dawg's Avatar
dawg
Default RE: Miles on TC 88
Have you had to at least replace the tensioners?
Old Jun 22, 2008 | 08:57 PM
Grayhawk's Avatar
Grayhawk
The rear gasket started leaking on the real cyclinder and i had it replaced.&nbsp\\; The shifter shaft seal has been replaced twice.&nbsp\\; I had the cam bearings and cam chain tensioners checked at 47,000 miles and they looked brand new.
Old Jun 22, 2008 | 09:03 PM
dawg's Avatar
dawg
That's amazing.&nbsp\\; If the tensioners were last checked at 47 and now ya got 63 I'd be checking them again.&nbsp\\; You usually don't see that high mileage on a set of tensioners without them torpedoing and taking something out with them.
Old Jun 22, 2008 | 09:24 PM
Grayhawk's Avatar
Grayhawk
i might have them checked this week.&nbsp\\; I am thinking about riding out to Sturgis and don't want any malfunctions.
Weavr99FLHT's Avatar
Weavr99FLHT
ORIGINAL: Grayhawk
The rear gasket started leaking on the real cyclinder and i had it replaced.&nbsp\\;\\\\\\; The shifter shaft seal has been replaced twice.&nbsp\\;\\\\\\; I had the cam bearings and cam chain tensioners checked at 47,000 miles and they looked brand new.
&nbsp\\;
not like "checking" the tensioners is an easy job - why didn't you just replace them when you "checked" them?&nbsp\\;&nbsp\\;Seriously - go thru the trouble of checking them......&nbsp\\; They do last longer with Synthetic oil.&nbsp\\; I've replace mine twice (25,000 and 53,000) and neither time they needed replacing but since I was in there might as well.....
HD cured the cam bearing problem by 2000.&nbsp\\; Just the tensioners that are an issue until 07.&nbsp\\;&nbsp\\;.&nbsp\\;
Old Jun 22, 2008 | 09:37 PM
Wally's Avatar
Wally
Don't check them this week, change them.
Old Jun 22, 2008 | 10:39 PM
Avmech97's Avatar
Avmech97
I made 95,000 on the original tensioners but replaced the cam plate,tensioners and also replaced the cams with stock takeoffs due to wear but still use the original inner cam bearings. The engine is now approaching 119,000 miles and still carries well over 35 psi of oil press. The top end is starting to get a little noisy but still runs great.[sm=biker2.gif]
Old Jun 22, 2008 | 10:57 PM
cripula's Avatar
cripula
ORIGINAL: Grayhawk
HD cured the cam bearing problem by 2000. \\\\\\; Just the tensioners that are an issue until 07. \\\\\\; \\\\\\;. \\\\\\;
Earlier 2000's still had the problem - mine did.
Old Jun 23, 2008 | 03:57 AM
Wally's Avatar
Wally
Actually , all TC engines built before Dec. 14th, 1999 had the defective bearings.
Since the 2000 model year bikes came out in July 99' , about half the 2000 bikes were or will be affected as the mileage on them increases and the problem surfaces.
