08 RG First Service
Old Jun 24, 2008 | 10:08 AM
ncbeast's Avatar
ncbeast
Default 08 RG First Service
Going with Synthetic.
&nbsp\\;
Anything else I should get them to check?
Old Jun 24, 2008 | 10:17 AM
garyhendley's Avatar
garyhendley
Default RE: 08 RG First Service
if is this your&nbsp\\;1st 1000 miles service they should check out everything for tightness
and fluid levels adjust clutch and brakes and give you a half azz wash too are you going
with harley syn or something better ??
Old Jun 24, 2008 | 10:34 AM
ncbeast's Avatar
ncbeast
Yes, this is the first 1000K service.&nbsp\\; Bike is 2 weeks old.
Using their synthtic this time since they are doing the work...didn't think I had a choice?
They are going to do the normal checks and lubs.
Also getting them to check..
Front end, seems to bottom out some and head light shake.
Also checking the engine light that come off and on twice before starting the bike.
Being really brief because sometimes what I write will not post.
Old Jun 25, 2008 | 07:45 PM
ncbeast's Avatar
ncbeast
I am going to get them to look at the front end...seems to bottom out over larger bumps.
&nbsp\\;
Also the engine check light comes on like normal and then off, get ready to start it and it comes on a second time then off and then starts fine and never comes on when running?
&nbsp\\;
Rear break squel...
&nbsp\\;
Anything else I should get them to check that they would not normally at the 1000K service?
Old Jun 25, 2008 | 10:43 PM
dawg's Avatar
dawg
ORIGINAL: ncbeast
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Rear break squel...
&nbsp\\;\\\\\\;
&nbsp\\;
They're not gonna do anything for your rear brake squeel....mine does it too. Change out the pads to Lyndall Z's and it will get alot better.&nbsp\\;The engine light is because you have a historical code probably, they can clear it or you can clear it. Run heavier fork oil in the front and that will help.
Old Jun 26, 2008 | 12:16 AM
Rocky Rox's Avatar
Rocky Rox
My local service mgr recommends using dyno oil for the first 5000 then changing to syn oil. He thinks the engine will break in better this way.
Old Jun 26, 2008 | 12:42 AM
heywood727's Avatar
heywood727
Mines the same as Rockey Rox. They will not go to Synthetic untill 5000 miles. After this point I can do my own with what ever I please as long as I keep all the documentation in order to keep my warranty valid.
Old Jun 26, 2008 | 03:39 AM
pandol34's Avatar
pandol34
Go with synthetic 80/90 gear in the trans or 90/140 if you live where it is really hot
HDRoadKing007
Exhaust System Topics
Jul 29, 2008 10:30 PM
FATBOB.
Jul 29, 2008 11:55 AM
Topspin
Jul 6, 2008 06:06 AM
harley_nova
Jul 5, 2008 01:13 AM
ConnMan
Jul 3, 2008 09:25 PM
