Backfiring on decelleration- electra glide classic
Old Jun 26, 2008 | 11:13 PM
sundown66's Avatar
sundown66
1st Gear
Default Backfiring on decelleration- electra glide classic
I have a&nbsp\\;2002&nbsp\\;\\electraglide classic with fuel injection- ever since having the cam tensioners replaced while on a trip I immediately started having a problem with the bike excessively backfiring on deceleration and it occasionally pops through the air throttle body.&nbsp\\; This never happened before having the cam tensioners replaced.The local harley dealer&nbsp\\;is having a problem coming up with the cause.&nbsp\\;They've replaced the pipes, tested for exhaust leaks, checked electrical components, done a valve leak down test and a fuel pressure test as well as all the computer diagnostic&nbsp\\; with all coming up having no problems.&nbsp\\; Dealership has done all they can do without starting to replace costly parts without a direction as to whats causing the problem....any ideas?? [align=right][/align]
Old Jun 26, 2008 | 11:15 PM
dawg's Avatar
dawg
Default RE: Backfiring on decelleration- electra glide classic
Did the dealer go back into the cam chest and check to make sure that the timing marks are all line up the way they are supposed to be, etc.?
Old Jun 26, 2008 | 11:36 PM
sundown66's Avatar
sundown66
1st Gear
Thanks dawg, would you happen to know if the timing marks are out if it would or could affect just the deceleration problem or would the bike also not run properly on acceleration...right now it operates fine on acceleration..
Old Jun 26, 2008 | 11:51 PM
Black Flag's Avatar
Black Flag
air leak in the intake tract?
Old Jun 26, 2008 | 11:57 PM
sundown66's Avatar
sundown66
1st Gear
thanks...do you mean externally to the engine or do you mean a valve inside the engine.&nbsp\\; Not sure what you're referring to.
Old Jun 27, 2008 | 12:43 AM
Black Flag's Avatar
Black Flag
I was thinking externally, the induction module has many sensors, flanges, injectors, etc. that are sealed by O-rings.&nbsp\\; If air is leaking through a bad rubber seal or O-ring, it could mess with AFR, and could possibly result in symptoms you describe.&nbsp\\;
Sarhan
Engine Mechanical Topics
Oct 17, 2016 12:11 PM
Missi
Dec 17, 2013 01:03 PM
sundown66
Jun 27, 2008 01:34 PM
sundown66
General Topics/Tech Tips
Jun 26, 2008 10:44 PM
kburks
Exhaust System Topics
11
Feb 23, 2005 01:03 AM
