Sticky Throttle
Old Jun 30, 2008 | 04:36 AM
IndyRider's Avatar
IndyRider
Default RE: Sticky Throttle
Quickie, I had a similar problem and found it was the throttle plate sticking.&nbsp\\; Took off the air cleaner and sprayed some carb cleaner on the plate and cleaned it up.&nbsp\\; Worked for me.
&nbsp\\;
Old Jun 30, 2008 | 08:16 AM
JCFLHRS07's Avatar
JCFLHRS07
Had that problem with my 07 RK after the dealer installed new bars and throttle cable, further investigation found there was too much slack and the cable was binding up, adjusted the cable and what do ya know it was fine, check if there is any play with the grip, you should be able to feel the cable pull when you turn the throttle, if it is loose adjust it till the play is gone.
big papa AZ
Mar 3, 2017 11:50 PM
matt_m_72
Apr 14, 2016 07:40 PM
scottbob99
Jan 18, 2016 01:56 PM
Tanker2
Apr 5, 2013 03:48 PM
Iron Man73
Ironhead
13
Feb 6, 2012 02:56 PM
