Changing Console Insert?
Old Jun 30, 2008 | 05:51 AM
Chuck1's Avatar
Chuck1
Default Changing Console Insert?
How does the insert come off the console of 08 FLHT?&nbsp\\; I may change it some day.&nbsp\\; I read in the service manual how to remove the console but it didn't sound like it was&nbsp\\;for an EG.&nbsp\\; I didn't get a chance to read it a second time but I couldn't find any of the screws they were talking about.&nbsp\\;
I assume you don't need to remove the console to change the insert but curious about both now.
Old Jun 30, 2008 | 11:00 AM
Dennydp's Avatar
Dennydp
Default RE: Changing Console Insert?
Instructions should come with the insert.I put the chrome HD one on my ultra and it was an easy job.If I remember right screws were by gas cap and under seat.Take console loose and more screws on bottom of console for insert.Quick easy job
Old Jun 30, 2008 | 11:04 AM
Fletch's Avatar
Fletch
On my '05 FLHTI, it was just put in place with two sided tape. I got my courage up and pulled at the edge and it came right off.
Old Jun 30, 2008 | 04:20 PM
Chuck1's Avatar
Chuck1
ORIGINAL: Dennydp
&nbsp\\;
Yeah, that's what my SM said but there aren't any screws under the locking cap.&nbsp\\; I know the 08 tanks are different than 07's.&nbsp\\; I think I even screwed the gas cap off too to make sure it wasn't covering.&nbsp\\;
I'll have to read that section again........................strange.
Old Jun 30, 2008 | 04:34 PM
HDCHROME110's Avatar
HDCHROME110
One bolt at the tank and one up top, take the cap off and lift it up - un do the wire hold down clips it comes right off. vent line can come off if need be.
[IMG]local://upfiles/61843/6A10BE47203147118E908C8A4FB2AA26.jpg[/IMG]
Old Jun 30, 2008 | 04:57 PM
garyhendley's Avatar
garyhendley
to change the insert i used a hair dryer to heat up the glue and use a putty knife
&nbsp\\;
it will come right up
Old Jun 30, 2008 | 08:41 PM
Chuck1's Avatar
Chuck1
Ok, I see the screws now to take the console off, if I need to.
I'll wait and see what the instructions say when I get it, thanks.
Old Jun 30, 2008 | 08:48 PM
AtkRWC's Avatar
AtkRWC
Here is what mine (06) looked like after swapping it out.&nbsp\\; Just pull and replace, its taped.
Old Jun 30, 2008 | 08:49 PM
Beemervet's Avatar
Beemervet
Use a hair dryer to soften the adhesive. Try to get some fishing line (maybe dental floss) under a corner and saw it back and forth. The only advantage to taking off the console is that there are a couple of places to push up on the insert. Be sure to remove all of the old adhesive. Follow the instructions with the new insert.
Old Jun 30, 2008 | 08:54 PM
nujohn's Avatar
nujohn
hair blower works the best , just go slow and clean all old glue befor new install
Drodrigueznyc
Milwaukee Eight (M8)
May 3, 2017 11:15 AM
LOTL
Aug 23, 2013 09:59 AM
mdwatsons
General Topics/Tech Tips
Sep 28, 2009 05:57 AM
Rickr01
Aug 18, 2009 04:28 PM
hdjoe88
Dec 28, 2007 11:41 PM
