Purchased Kit # 50830-07 Angled Highway Peg Mounting Kit. \\; Based on the attached Instruction Sheet, I assumed the footpeg is towards the front tire. \\; Installing \\;the kit as presented in the instruction sheet, my 5'10 1/2" frame isn't capable of resting my boot on the footpeg. \\; \\; Tooooooooooooooooo far to stretch. \\;
Any suggestions for this non-wrench?
TIA
Turn the arm around so that it is closer to you. \\;\\\\\\; I have those on mine and I'm only 5' 10" as well. \\;\\\\\\; With those arms, you can just about put the peg in any position you want.
Turn the arm around so that it is closer to you. \\;\\\\\\;\\\\\\\\\\\\\\; I have those on mine and I'm only 5' 10" as well. \\;\\\\\\;\\\\\\\\\\\\\\; With those arms, you can just about put the peg in any position you want.
In AM will switch the arm around and that should do it. \\; The peg is currently toooooooo far away to rest my foot on it. \\; Misread the instructions.
Thanks
I have the same ones. \\; They need to come back to you. \\; If you have not figured it out these are a PIA to get setup. \\; If I had to do it all over again I would have bought a simpler straight mount.
