RK driver backrest ?
Old Mar 8, 2006 | 11:57 PM
Roadie 49's Avatar
Roadie 49
Default RK driver backrest ?
Will the adjustable back rest give me the lower back support , and
not push me forward on the seat? Looking for a back rest that I can
kind of lean back into, and not have it jammed into my lower back.
I'am running a stock FLHRI seat , that was gutted and redone.
Thanks
Old Mar 8, 2006 | 11:59 PM
MACK's Avatar
MACK
Default RE: RK driver backrest ?
there are 3 types. you want the expensive adjustable one that has the gas shock. it adjusts 30 degrees back and forth.
Old Mar 9, 2006 | 12:12 AM
Lpye's Avatar
Lpye
I have the one with the adjustable shock on an E-glide. I am 6'1" and 280 lbs. It works well for me. You can adjust it on the fly as well.
Old Mar 9, 2006 | 12:54 AM
R1Geezrglide's Avatar
R1Geezrglide
I've got the standard backrest with the stock pillow-look seat ( '02 FLHT ). The bracket tilts at a rearward angle so putting it in the highest position also moves it the furthest rearward. With the cushion in the highest position, it makes a lump in the center of the seat pocket that pushes me forward about an inch. That repositioning put me on a hump in the seat pan that makes me feel like I am sitting on a padded drain pipe. After several hundred miles trying to adjust the backrest pad tilt set screw, I gave up and put it in the saddlebag. I rechecked my installation to see if I had done something wrong, but no. it was correct. I am very disappointed that it isn't designed better than that. The bracket needs to be another inch rearward so it doesn't deform the rider seat pocket. It's not like this is an item they just came out with. So, I am looking to try a different seat or fabricate my own backrest bracket. BTW, I am 6'1", 225lbs.
Old Mar 9, 2006 | 09:22 AM
100thRK's Avatar
100thRK
I have the rider backrest #52914-98. It works great for me. It has multiple adjustment points. It took me a few rides/adjustments but once I got it right it works well for me.
Old Mar 9, 2006 | 09:26 AM
bountyhunter's Avatar
bountyhunter
Rarely ride without it. Great support and comfort once you get it adjusted perfect.
Old Mar 9, 2006 | 09:42 AM
carsoni's Avatar
carsoni
I have the adjustable one with the SUNDOWNER, use it all the time.
Old Mar 9, 2006 | 02:07 PM
Cohiba_Joe's Avatar
Cohiba_Joe
I see you are running a rider backrest with a Sundowner seat. I am running a Sundowner Solo and was hoping someone could direct me to a backrest that would work with it.
Thanks,
Brian
Old Mar 9, 2006 | 02:47 PM
1potter1's Avatar
1potter1
i rode a RK for 3 years with a mustand seat #79102 w/backrest. very comfortable and will adjust up and down and back and foward. ive ridden alot of hiway miles with the mustang seat and backrest which will allow you to layback in a comfortable position with highway pegs.. i have a Ultra now with harley adjustable backrest and the HD backrest does not even come close to the mustang.
http://www.mustangseats.com/hdcontst.htm
Mr.Softy
Nov 19, 2010 04:00 PM
webbug
Dec 8, 2009 07:42 PM
Pezz
Jul 12, 2009 02:59 PM
tincup64
Apr 13, 2009 06:54 AM
dionne51
Sep 30, 2006 09:51 AM
