07 to 08 Front Wheel Change
Old Jul 2, 2008 | 08:41 PM
cycleboy1450's Avatar
cycleboy1450
Default 07 to 08 Front Wheel Change
&nbsp\\;I have a 2007 Roadking Custom&nbsp\\;and want to put&nbsp\\;a front wheel from&nbsp\\;a 2008&nbsp\\;Street Glide on.&nbsp\\; The axle sizes are&nbsp\\;different&nbsp\\;from 07 to 08.&nbsp\\;&nbsp\\;If I use the 08&nbsp\\;axle and spacers on my 2007 King?&nbsp\\; And then use the 07&nbsp\\;axle and spacers for the 08&nbsp\\;Street Glide.&nbsp\\;&nbsp\\;Will this work?&nbsp\\; The forks will be&nbsp\\;issue if there&nbsp\\;is any.&nbsp\\;&nbsp\\;&nbsp\\;
Old Jul 2, 2008 | 09:00 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: 07 to 08 Front Wheel Change
The brake rotors are also different from '07 to '08.&nbsp\\;\\\\\\; The '08 brake rotors are slightly bigger than the '07's so you'd have to swap those as well along with the Brembo calipers[sm=outcold.gif].&nbsp\\;
Your easiest solution is to stay within your model year unless someone else see's something that I may have missed.
Old Jul 2, 2008 | 09:56 PM
Pickard USA's Avatar
Pickard USA
Former Sponsor
the 08's have a 25mm bearing and axle.&nbsp\\; If you were to put the 08 wheel on the 07, you would need to change out the bearings to fit your 07 axle and possibly have to change/have some new axle spacers made.&nbsp\\; He is right about the 08 rotors.&nbsp\\; they have a slightly larger diameter, however, you can bolt on your 07 rotor to the 08 wheel.&nbsp\\; HD didn't change the bolt hole pattern on the hubs.&nbsp\\; Hope this helps!
stev0n
Aug 8, 2012 08:54 PM
mjmangus
EVO
May 9, 2012 06:23 AM
Scheers44
May 28, 2010 02:23 PM
MarksBOB
Aug 31, 2008 05:58 AM
adlerx
Apr 3, 2008 06:46 AM
