Bad Belt?
Old Jul 4, 2008 | 10:30 PM
TBite's Avatar
TBite
Stage II
Default Bad Belt?
I have a 04 Electra Glide Standard, 22,000 miles. The belt is making a squealing noise. I have cleaned it with warm soaping water (tooth brush), rinsed off good, inspected it with magnifying glass (looks good), adjusted belt and still same noise. I bought some belt lube from HD fixed problem for the first 50 miles, re-applied more lube fixed problem for about 50 miles again. What do you think?
Old Jul 4, 2008 | 10:33 PM
Dr.Hess's Avatar
Dr.Hess
Default RE: Bad Belt?
Check the alignment of the back wheel and if that's good, the alignment of the motor/trans as well.&nbsp\\; Put the back wheel up on your stand/lift and spin the back wheel with the trans in neutral.&nbsp\\; Does the belt run in the center or wander to one side?
Old Jul 4, 2008 | 10:37 PM
TBite's Avatar
TBite
Stage II
I will check it, thanks for the reply..
bogie
14
Mar 23, 2022 08:56 AM
Mihail Petev
Oct 21, 2018 05:28 PM
NoRegerts
Jun 4, 2013 10:36 AM
CrazyMC
Sep 10, 2008 08:58 PM
vtarandy
Oct 18, 2007 06:27 AM
