oil filter
Old Jul 6, 2008 | 12:12 PM
dirtdobber's Avatar
dirtdobber
Default oil filter
I am starting to change my own fluids and trying to figure out how to get the oil filter off without making a mess. I have a 07 Ultra with premium cooler.
Any ideas that might work.
jim
Old Jul 6, 2008 | 01:06 PM
stro1965's Avatar
stro1965
Default RE: oil filter
Try cutting the bottom out of a 2 liter pop bottle and running your socket/extension through the small hole.&nbsp\\; Slip the big hole under and around the filter while you wrench it off.&nbsp\\; Most important thing in the long run it to try to keep the oil off of that front motor mount.&nbsp\\;&nbsp\\;Good luck, it ain't easy!
&nbsp\\;
Old Jul 6, 2008 | 01:12 PM
dirtdobber's Avatar
dirtdobber
Thanks i heading out to give it a try. When I installed the oil cooler I put a piece of tin foil it didn't work to good. Your right it isn't easy.
again thank you
jim
Old Jul 6, 2008 | 02:58 PM
G wizz's Avatar
G wizz
&nbsp\\;
&nbsp\\;The way I've been doing it, and loose very little oil is to make a trough out of tin foil, and kinda shove it up under the filter and down to a pan. THEN, take a long pointed punch and poke a hole in the end of the filter near the botom, and&nbsp\\; one near the top of the filter&nbsp\\;(you&nbsp\\;wern't going to use the filter again anyway) let the oil drain out of&nbsp\\;hole in the&nbsp\\;filter into your tin foil trough. when it's done draining, spin off the filter. You will find out you have very little oil to wipe up.
&nbsp\\;
&nbsp\\;G wizz
Old Jul 6, 2008 | 03:17 PM
blueflht's Avatar
blueflht
i use cardboard to slide under filter. poke hole let it drain. DO NOT USE CHEMICALM CLEANERS AROUND FRONT MOTOR MOUNT! rubber very sensitive to chems will deteiorate and crumble in a very short time
Old Jul 6, 2008 | 05:52 PM
cms1528's Avatar
cms1528
The 2 litre bottle works very well, if you feel like spending your money J&amp\\;\\\\\\;P cycles has a oil drip pan that fits up against the filter and catches the mess. It cost about $20.
&nbsp\\;\\\\\\;
http://www.jpcycles.com/productgroup...4-9B8C541CC8FC
Old Jul 6, 2008 | 05:57 PM
rinja64's Avatar
rinja64
Well, for me, I tried the plastic bottle thing, the foil thing...I just jam a bunch of paper shop towels under the filter...I have yet to find something that works without a mess...Good luck...
Old Jul 6, 2008 | 06:16 PM
pandol34's Avatar
pandol34
I use the gear lube bottle (from my trans change) as a funnel.&nbsp\\;&nbsp\\;I've cut it to fit and it works well.&nbsp\\; You can also take the box the filter comes in and fold it flat placing it under the filterto form&nbsp\\;a make-shift funnel.&nbsp\\; I like the quality of a K&amp\\;N filters and the removal nut manufactured on the end that lets you remove it easily.
Old Jul 6, 2008 | 08:04 PM
dirtdobber's Avatar
dirtdobber
I thank each of you for your suggestions. I ran out of time so I will takle it Tuesday.
again thank you
jim
Old Jul 6, 2008 | 08:08 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i cut up an old towel and packed it in pulled it out as soon as filter was off
jd8181
Mar 4, 2020 09:02 PM
deadman77
Oct 18, 2015 06:45 AM
cdestuck
Apr 29, 2010 09:16 AM
deerjackie
Oil Archive (no new posts)
Jul 5, 2008 03:40 AM
erockguide
Jun 25, 2008 08:49 AM
