Need help with Baffles
Old Jul 7, 2008 | 05:11 PM
biggron's Avatar
biggron
Default Need help with Baffles
I have a set of SE II slip ons on my 06SG and IM fixen to pull the baffles out and put in some big city monster baffles .Just wondering what I need to do to pull out old and put in new.Im not the most mechanicly inclined SOB in the world so I thought Id ask before I Start removing anything.
Old Jul 7, 2008 | 06:46 PM
pajoe's Avatar
pajoe
Default RE: Need help with Baffles
I just removed the core on a 65254-00 muffler, part of the Touring Muffler set 65259-00 , it was held in place by two welds, I used a small grinder (Dremmel tool) to grind down the welds, then sprayed some WD-40 to help it slide out > turned the muffler to the other end and used a metal rod similar to a 1/2 " long extension to tap on the edge of inner most tube, and it took a while to get it out that way.
If you look at the picture, the 3 5/16 " end had the 2 welds, located easily after removing the end cap and the 1 3/4 OD tube on the other end is what I hit to push it out.
[IMG]local://upfiles/1956/04CD93AA535249AEBA6259703FEA4F03.jpg[/IMG]
Old Jul 7, 2008 | 08:05 PM
Spartan's Avatar
Spartan
Which SEII mufflers do you have?
tbrenn27
Jun 24, 2016 01:56 PM
ksjayhawk
Exhaust System Topics
Aug 4, 2010 10:20 PM
qwiktripp
May 16, 2010 02:21 PM
mcline_1968
Jan 6, 2008 01:28 PM
110RDKNG
Sep 20, 2007 11:35 PM
