removing tour pack
Old Mar 11, 2006 | 01:40 AM
wjl24's Avatar
wjl24
Default removing tour pack
I've got a 95 Ultra and Harley says I can't get the detachable set up for that model and year. I would like to be able to remove tour pack and install backrest and rack. I don't care if it is quick detach or if it takes an hour to swap out. Has anyone done this? Can you tell me what will work?
Old Mar 11, 2006 | 01:54 AM
MACK's Avatar
MACK
Default RE: removing tour pack
that is true. all the detach stuff is for 97 and later. i f you want to go to the expense you could change fender hardware and strutts or check the aftermarket. dennis kirk and j&p cycles are good starting points for this stuff.
Old Mar 11, 2006 | 11:26 AM
soos's Avatar
soos
Why do you wanna do this? You bought an Ultra because it is an Ultra.
Old Mar 11, 2006 | 11:58 AM
Kess's Avatar
Kess
To make a rich man's Street Glide??
There does seem to be a lot of interest in this lately and I think it is cool. I have it on next winter's list of things to do. For me it's all about options and having the best of both worlds. I can see lot's of reasons for doing this but most of all cause it's FUN!
Old Mar 11, 2006 | 12:01 PM
Basz's Avatar
Basz
Here are some excellent post from guys that did it. Not sure if this pertains to a 95 - others will know.
When my Ultra gets here I plan on making the tour pak a detachable.
I have these post saved because of the great info in them from guys that already did it and were kind enough to share the knowledge (thanks).
Taking the Dress off a Dresser
Removable Tour Pak
Tour-pak Detachable Docking Kit
Hope this helps
flattracker60
Feb 2, 2014 06:19 AM
Doc R.K.
Aug 28, 2013 08:40 PM
TN 0208
Mar 23, 2013 09:24 AM
ultra08classic
Apr 2, 2009 06:38 PM
alandchris
Feb 7, 2009 07:47 AM
