I had a 2000 Road King Classic with dealer installed HD Security System. \\;\\\\\\; They came out with it in 2001 or 2002 if I remember correctly. \\;\\\\\\; Anyhow it had a wiring harness of its own that was spliced into the factory harness and used the same components as a factory installed system. \\;\\\\\\; It worked great the whole time I had the bike. \\;\\\\\\; I came with a manual (HD) and in that manual was a section on how to adjust the sensitivity. \\;\\\\\\; \\;\\\\\\; I had mine adjusted to the point that if you bumped the handlebars it would give the warning chirp. \\;\\\\\\; I sold that bike recently and bought a 2008 Street Glide with security. \\;\\\\\\; The info for the security system is in the owners manual now and it doesn't mention anything about adjusting the sensitivity. \\;\\\\\\; I gave the guy that bought my Road King the factory manual for the security system so I can't look to see what the procedure was for that particular adjustment. If anybody has an older model with the little black instruction book that came with the system it'll be in there. \\;\\\\\\; Could you please let me know the procedure so I can see if it works on the new systems. \\;\\\\\\; You can almost knock my new bike over before it goes off. \\;\\\\\\; If anybody has any info please let me know.
THANKS IN ADVANCE!!!
Here it is for an 06
Turn IGN key ON-OFF-ON-OFF-ON
Press L turn switch 2 times and release
Press key FOB button until confirmation is received, 1 flash of turn signals
Press L turn switch 1 time and release, turn signals flash to indicate the current option
1 flash- extremely low
2 flash- low
3 flash- medium
4 flash- high
Press L turn switch to advance through options, turn signals flash to indicate new option
Turn IGN key OFF
No adjustment is possible. I had several items stolen on my o8 Ultra, took it in to see if it could be adjusted as I did not see anything in the manual. Dealer at first thought it was adjustable but found out that no adjustment is possible
Another reason to stick with aftermarket security systems...
