how many gallons
Old Jul 14, 2008 | 08:08 PM
Bluesssman's Avatar
Bluesssman
Default RE: how many gallons
ORIGINAL: FXSTDSE2
Stopped at a station and the towel heads were draining the hoses between fill ups when it was slow. It took .4 gallons to recharge the hose. Of course I told Pull-Start to reset the pump. Sh*t, .4 gallons is like 2 bucks!
What are towel heads?
Old Jul 14, 2008 | 08:11 PM
glens's Avatar
glens
Women with wet hair.
Old Jul 14, 2008 | 09:09 PM
skratch's Avatar
skratch
ORIGINAL: glens
Assume 1/2-inch ID everywhere for hose, etc. 10 lineal feet is almost exactly 0.10 gallons by volume.
At 3/4-inch ID everywhere, 10 feet is 0.23 gallons.
Probably not 3/4-inch ID stuff, maybe 5/8. If so, split the difference for close-enough.
Call it 15 feet for 1/2-inch = 0.15 gallons.
For 3/4-inch = 0.34 gallons.
It is why I do not just top off at single-hose pumps. Full fill-up is not the end of the world. I just hate getting any gas cheaper than I paid for and leaving some more-expensive for the next guy who probably buys the cheap stuff.
but then you have to take into account that the hose is attached up top.&nbsp\\; so that the length of the hose from the top of the pump to the handle is not included in that equation.
Old Jul 14, 2008 | 09:23 PM
tazer1's Avatar
tazer1
Don't forget the actual pump and filter. They stay primed and the filter is the size of an auto oil filter. They sometimes can hold almost a quart.
Old Jul 14, 2008 | 09:29 PM
Mars's Avatar
Mars
I switched to medium grade on my FXST and it runs better. Mileage improved by like 2 mpg. Offhand I dont know the compression ratio of the 96 motor. Anyone?
Old Jul 14, 2008 | 11:18 PM
glens's Avatar
glens
ORIGINAL: skratch
but then you have to take into account that the hose is attached up top. so that the length of the hose from the top of the pump to the handle is not included in that equation.
15 feet would not get it?
ORIGINAL: tazer1
Haven't been in a dispenser. Aren't they submersible pumps with just above-ground plumbing to a valve block? Pretty sure each grade would have its own filter.
Old Jul 14, 2008 | 11:24 PM
sling blade's Avatar
sling blade
6th Gear
One more reason to fill up at the stations with a separate hose for each grade of fuel.&nbsp\\;
Old Jul 16, 2008 | 07:26 AM
JustLoafin's Avatar
JustLoafin
It shouldn't be allowed!!!!!!!&nbsp\\; I will always try to support the stations with serperate hoses.&nbsp\\; Getting tougher though!!!!
Old Jul 16, 2008 | 07:37 AM
Windup08's Avatar
Windup08
A friend that works on gas station pumps told me there should be no residual gas from the previous person as the pumps have a "pull-back" operation that sucks the gas back down when the pump is shut off. You should be getting 100% of the grade you selected.
Old Jul 16, 2008 | 07:45 AM
Korbenw7p3c's Avatar
Korbenw7p3c
ORIGINAL: glens
Nice save!&nbsp\\; Being political and all.
