Tried to Shortcut It
Old Jul 15, 2008 | 09:05 PM
EasternSP's Avatar
EasternSP
Default Tried to Shortcut It
I replaced my front rotors with floating.&nbsp\\;\\\\\\;I didn't have the right size E socket to remove the pad pins. I only used a screw driver to force the pads back into the caliper with the cap off the reservoir. Those brakes are so locked up I cant push the bike. Ill take it apart again tomorrow and do it right.
BTW, what size Esocket is the pad pins?
Old Jul 15, 2008 | 09:06 PM
Bryan TTM's Avatar
Bryan TTM
Default RE: Tried to Shorcut It
1/4&nbsp\\; 12 point i think
Old Jul 15, 2008 | 09:10 PM
EasternSP's Avatar
EasternSP
I have one of those but it doesnt fit. Its the reverse of the Torx socket but it takes a E socket.
Old Jul 15, 2008 | 09:13 PM
Bryan TTM's Avatar
Bryan TTM
i got a socket that works....but its at the shop....i'll tell ya tomorrow what it is
Old Jul 15, 2008 | 09:41 PM
EasternSP's Avatar
EasternSP
When I tried a 1/4" socket it seemed to fit tight until I put a ratchet on it, then it slipped.
Old Jul 16, 2008 | 07:16 AM
billnourse's Avatar
billnourse
Default RE: Tried to Shortcut It
1/4" 12 point is the size needed to remove the pad pins unless they changed something for '06.&nbsp\\; this is the size that fits my '05 EGC.
&nbsp\\;
Bill
Old Jul 16, 2008 | 07:26 AM
miacycles's Avatar
miacycles
They are 1/4" twelve point, we had a customer try to take them off with a six-sided socket and rounded off the pin. We had to take the caliper apart to get the pins out.
Old Jul 16, 2008 | 07:32 AM
EasternSP's Avatar
EasternSP
Ok, Ill have to hit the autoparts store and see if they have one.&nbsp\\;Thanks.
Old Jul 16, 2008 | 08:12 AM
Bertk's Avatar
Bertk
The PDF file on the following page may be of help.
http://motorcyclemetal.com/Download4.html
Old Jul 16, 2008 | 09:22 AM
Harleypingman's Avatar
Harleypingman
A 1/4" combination wrench will work if you have trouble finding the socket.
