fairing bracket fracture
Old Jul 16, 2008 | 07:10 PM
Bad Pig's Avatar
Bad Pig
Default fairing bracket fracture
ok, i assume this is an issue i haven't read yet. noticed it when i took the radio out, facing the bike with the outter fairing off on the right side at the very top mounting point on the inner fairing. any good fix ideas?? thanx
Old Jul 16, 2008 | 07:18 PM
Olde Skool's Avatar
Olde Skool
Default RE: fairing bracket fracture
https://www.hdforums.com/m_1855624/tm.htm&nbsp\\; Mine was fixed under warranty.
Old Jul 16, 2008 | 07:38 PM
StreetGlider56's Avatar
StreetGlider56
Mine was covered under warranty also....
Old Jul 16, 2008 | 07:51 PM
Bad Pig's Avatar
Bad Pig
wow....i guess i'm not the only person, guess i'll be stopping by home depot for some "L" brackets...ugh
Old Jul 16, 2008 | 08:46 PM
Bill03E's Avatar
Bill03E
I say so what if it is under warranty they just replace it with the same thing that broke in the first place, I just had one brake when I was riding to work yesterday, so I pulled it in the shop(I'm the boss, and I am early) pull the outer, and the bracket weld it up with stainless wire,then I added a stainless 1/8th inch rod over the area that brakes all the time, I doubt that it will brake again. &nbsp\\;
Old Jul 16, 2008 | 08:51 PM
Lucky_one2's Avatar
Lucky_one2
If you take a picture of the failure and send it to the MoCo will they will send you a patch?
&nbsp\\;
Oh, my bad... that was some other MoCo program.&nbsp\\; Don't bother with the warranty repair... it will just break again... "L" bracket repair works best IMO.
Old Jul 16, 2008 | 09:11 PM
oldhippie's Avatar
oldhippie
&nbsp\\;
Here's my fix. About $.49 worth of parts at the hardware store.. won't break again.
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jul 17, 2008 | 03:53 PM
Primo's Avatar
Primo
ORIGINAL: oldhippie
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;
Nice job oldhippie. This is the simplest and least expensive of a multitude of fixes I've seen for this issue.
Primo
Old Jul 17, 2008 | 05:04 PM
oldhippie's Avatar
oldhippie
Thanks, you need a drill and a steel drill bit to put a hole into the bracket upright, but after that nothing but a bit o blue loctite for the hexscrew. Took longer to take the fairing off than it did to make the fix.
Cattivo
Sep 20, 2014 07:47 AM
radicalchop
Jan 28, 2011 09:26 PM
texaswiz
Mar 26, 2010 08:53 PM
Buzzy204
Sep 27, 2009 06:00 PM
ddwyer
Jun 1, 2009 09:58 AM
